Hello, I'm new to these forums and was curious to if anyone could help me out.
I recently came across an old surround sound receiver and figured I'd make some use of it since I no longer have any sort of stereo to use. I went and bought a set of the Monoprice 8247 5.1 Surround Speakers that I planned to use with my receiver. The only problem is once i got the speakers in the mail I wired it all up just to find out that the auxiliary port on the receiver does not work. This is how I planned to wire it up. I wanted to plug into my computer to use for movies/gaming etc. So now pretty much I'm looking for a new reciver to use.
The speakers 5 speakers i have are each 125watts, 8ohm, and 150 Hz - 20 kHz. And the sub woofer is at 60watts (RMS), and 50 Hz to 250 Hz.
I'm trying not to spend a ton of money on a new reciver but would also like something with the possibility of using with better speakers in the long run
I was looking around on newegg yesterday and came across a few things i believe might work, but i really want to make sure before i go spending anymore money.
I was looking at the 1000watt Technical Pro RX38UR and the 1500watt Technical Pro RX-B503. I'm not really sure what I should get or if either of these would even work.
Please let me know. Thank you.
