need help with small home lighting project
noel
Hello,
I need to build a remotely computer controlled 4way light switch. I
want to do some home automation, and I can't use normal x10 3way
switches. So, I need to build something. Most of the lights I want to
conrtol are on 3way circuits. And the cost (in number of switches) and
the color of the paddles excludes x10 switches as an option. All the
switches paddles are black, and some are combination (3way/spst)
devices.
I want to take a DPDT relay and use it as a 4way light switch. Using a
DPDT relay takes care of the switching of the traveller wires on the
3way/4way circuit. But now I'm left with a couple of problems.
Upon looking on the net for relays, I've found two types. One is a
latching relay that just requires momentary current to switch the
relay, but these are low voltage DC for the coil, and use pos/neg to
switch. The others are non-latching and require a steady AC current to
maintain an 'on' state. I really don't want to use this type of relay.
Is there any other type of relay? Something that uses momentary ac to
switch?
I would like to use x10 to control the switch/relay. It would be nice
to have a switch unit that didn't need control wires running to it.
Not that I'm against running more wires, like low voltage to control a
latching relay. It's just that on the computer side, there is more x10
software and interface hardware to choose from (that I know of).
Another problem is sensing if the light is on. I've seen little loop
sensors that send an induced voltage to a universal x10 module. But,
this seems a little problematic. if you try to sense on the two
traveler wires, you have to use two sensors and travler wires seem to
have some voltage induced in one by the other.
With what little i know, I guess my best choice is to use a latching
relay that uses low voltage dc to control the relay and run wires to
some kind of interface, and figure out someway of load sensing.
If anyone could give me a few suggestions on how to accomplish this,
or offer some other ideas, it would be of great help.
Jim Backus
Hello,
devices.
At the risk of making a complete fool of myself, because I'm not
familiar with either US wiring practice or X10, but if there is an X10
3 way switch, surely this is suitable for an n-way switch?
A 2 way switch operates with a single pole double throw switch at each
switch position. The moving contact is linked through a 3rd wire. The
first wire connects fixed contact 1 of both switches together, and the
second wire connects fixed contact 2 of both switches together.
The 3 way switch is a 2 pole 2 throw switch which is wired as a
changeover switch and is wired in series with wires 1 & 2. Because the
3 way switch is a 2 pole changeover switch and number of these can be
fitted in the circuit.
My apologies if this is completely wrong!
Jim Thompson
[snip]
Only the names are wrong
2-way is single-pole-single-throw, ordinary switch
3-way is single-pole-double-throw, on each end of a multi-switch setup
4-way is double-pole-double-throw, located *mid-stream* on a
multi-switch setup
The naming "convention" seems to be based on number of terminals and
not on something sensible/meaningful ;-)
...Jim Thompson
N. Thornton
Hi Noel.
This is as clear as mud.
Hello,
meaning?
I
meaning?
devices.
what are?
traveller wires?
3way/4way circuit.
the what?
switch?
sounds an elementary issue.
for what purpose?
Yes, clarity would be good.
Regards, NT
noel
I believe that the UK and the US refer to these switches differently.
I've seen this noted on a couple of websites.
Michael A. Terrell
multi-switch setup
...Jim Thompson
Sure it makes perfect sense, if you're an electrician! They count the
number of positions, before you start the cycle over.
K
Keith R. Williams
X10 3-way switches can be used to form N-way switches. Basically the
X10 3-way has a master and a slave. The slave is momentary switch that
signals the master to toggle using one of the "travelers". The other
traveler is used to switch the current. To create an n-way switch one
simply wires the slaves such that each signals the master.
