Need help with intermittent circuit failures - JK Flip Flops
petrus bitbyter
Jason S said:
OK, try this site: http://www.jason3712.zoomshare.com/
I might post some photos on there too if I have time, so that you get the
idea of my project. But for now, I have only included the schematic. Let
me know if it's successful or not =)
Jason.
Jason,
Found the schematic. Do you really switch the power for the 555 with that
reed switch? If so it explains the problem very well. As the 555 may not be
stable immediately after power on, the 555 may miss an incoming pulse from
time to time. When switched off, the bounce of the reed contact will shake
the timer which may produce some false pulses, sometimes called spikes, to
the 4089. C5 will mask this behaviour to some extend.
I see you switch the relay and the motor using the same signal. As the
transistor is much faster then the relay, the motor will get current before
the relay has switched, but as the relay is much faster then the motor I
doubt you will see it move into the wrong direction. Nevertheless it may
produce disturbances and I advise to delay the signal to Q1 for some ms. A
couple of 4069 inverters along with an RC combination will do the trick.
Why should the monostable be triggered at power on? At power on the motor
will start to turn anyway so sooner or later you will meet the magnet.
petrus bitbyter
John Fields
1. A 4059 is a programmable counter, not an inverter.
2. The reed switch should _not_ be used to supply power to the 555.
The 555 should be connected across the power rails and the reed
switch should only be used to do the triggering.
3. Your triggering polarity is wrong. It should be a short
negative-going spike. Here's how the 555 should be wired:
(View in Courier)
+12V-+---------+---+----+-------+------+
| | | | |8 |
[10K] [10K] +->[POT] +---+---+ |
| | | 2|_ Vcc _|4 |
+-[0.1µF]-+--------|--O|T R|O-+
| | 6| |3
| O +---|TH OUT|------
| O | 7|_ |5
SW1| +--O|D VC|----+
| +| | GND | |
| [10µF] +---+---+ [0.1µF]
| | |1 |
GND>-+------------------+-------+--------+
3. The motor drive logic is bad because when the 555 times out its
output will go low, driving U2-2 high. This will toggle the JK
and send power to the motor at the same time. Unfortunately,
power will be sent to the motor before the direction relay has a
chance to toggle, so the motor will be starting to spin up
when the relay opens, cutting off power to the motor and then,
when it closes on the other set of contacts, plugging the motor.
OUCH!
To keep that from happening, what you need to do is cut power to
the motor first, when the reed relay triggers the 555, then, when
the motor stops spinning, toggle the relay, and then reapply
power to the motor, like this:
|-->T1<--|
____ _______ _ _ ____ ________ _ _
U3-3 |________| |________|
_______ _ _ _____________
u3-1 _____________| |________ _ _
|<---T2--->|
__________ __________
U1-3 ____| |_____ _ _ ____| |______ _ _
____ _____ _ _ ____ ______ _ _
U2-2 |__________| |__________|
The trick here is to make sure that T1 doesn't go high until the
motor stops turning and to make sure T2 lasts long enough so that
RL1 changes state and all contact bouncing has ceased before U2-2
goes high and sends power to the motor.
Arguably the easiest way to do that with what you have so far is to
add another 555, like this:
| | | | U1 |8 |
[10K] [10K] +->[1MR] +---+---+ |
| | | 2|_ Vcc _|4 |
+-[0.1µF]-+-+------|--O|T R|O-+ U2
| | | 6| |3 1| \ 2
| O | +---|TH OUT|-----O| >---> TO U3-3
| O | | 7|_ |5 | /
SW1| | +--O|D VC|----+
| | +| | GND | |
| | [1.2µF] +---+---+ [0.1µF]
| | | |1 |
GND>-+-----------|------+-------+--------+
+12v>------------|------+-------+------+
| | U4 | |
| [1MR] +---+---+ |
| | |_ Vcc _|4 |
+------|--O|T R|O-+
| | |3 | \
+---|TH 0UT|-----O| >---> TO R2
| |_ | | /
+--O|D VC|----+
+| | GND | |
[1.5µF]+---+---+ [0.1µF]
GND>--------------------+-------+--------+
Also, to keep any kickback from the motor from hurting Q1, you could
connect two 15V Zener diodes in series opposition across the motor.
The timing for the monostable 555 is:
T = 1.4RC,
so for U1, which controls the changeover relay, you'd want a timeout
longer than the spin-down speed of the motor, say 1-1/2 seconds.
Using a 1 Megohm resistor for timing means the capacitor would have
to be:
T 1.5s
C = ------ = ------------ ~ 1.07µF
1.4R 1.4 * 1E6R
If you use an electrolytic with a tolerance of +/-10% and a resistor
with a 5% tolerance the whole thing could be off by 15% on the low
side, so to keep that from happening you'll need to increase the
capacitance by 10% and the resistance by 5% or make the cap large
enough to swamp out the whole thing. A standard capacitance value
is 1.2µF, which should do it. Checking:
T = 1.4RC = 1.4 * 1E6R * (0.9 * 1.2E-6F) = 1.512s
So that works. if you need a longer timeout increase the value of
either R or the C.
The same thing goes for U4, except that you'll want to make its
timeout longer in order to let the relay get stable before you send
power to the motor. I've set a time constant of about 2 seconds
using 1.5µF.
So that's it, except for an annoying little detail which just hit
me, and that's that the reed switch is going to bounce when it's
released. That'll confuse the circuit by making it think that it
got a valid switch closure, and may be part of the problem you're
having now. In any case, I'll post this now and a solution for the
bounce problem later on today or tomorrow.
John Fields
Here ya go. Since you had half of the JK left over, and some
inverters as well, I made a debouncer out of the JK and split the
drivers into two sections; one for the relay and one for motor
power. Make sure you disconnect R2 from U2-2 and/or U3-3 if you use
my circuit. Following the schematic is a partly fleshed out LTSPICE
simulation. Enough to see that the logic and the noise filter /
debouncer works. Enjoy! :)
+12V>-+-------+
| | U3B
O [0.1µF] 4027
| | 9+-------+15
SW1| <--O--+------|S1 Q1|--[1MR]--+
| 13| |12 |
[10K] +--|>1 R1|---------+
| |10| | |
GND +--|J1 | [2.2µF]
|11| _ |14 |
+--|K1 Q1|---+ GND
GND |
+12V>--+--[10K]--+-----[0.1µF]---+
| | | U1 |8 |
[1N4148] | [1MR] +---+---+ |
| | | 2|_ Vcc _|4 |
+---------+------|--O|T R|O-+ U2
| | 6| |3 1| \ 2
| | 7|_ |5 | /
| +--O|D VC|----+
| +| | GND | |
| | |1 |
GND>-------------|------+-------+--------+
| | U4 | |
| [1MR] +---+---+ |
| | |_ Vcc _|4 |
| | |3 | \
| |_ | | /
+--O|D VC|----+
+| | GND | |
GND---------------------+-------+--------+
Version 4
SHEET 1 1972 1056
WIRE -1280 400 -1280 -80
WIRE -1280 544 -1280 480
WIRE -1280 592 -1280 544
WIRE -1168 400 -1168 144
WIRE -1168 544 -1280 544
WIRE -1168 544 -1168 480
WIRE -1072 400 -1072 240
WIRE -1072 544 -1168 544
WIRE -1072 544 -1072 480
WIRE -976 544 -1072 544
WIRE -976 544 -976 288
WIRE -928 240 -1072 240
WIRE -928 288 -976 288
WIRE -880 144 -1168 144
WIRE -880 224 -880 144
WIRE -880 352 -880 304
WIRE -880 432 -880 352
WIRE -880 544 -976 544
WIRE -880 544 -880 512
WIRE -816 -80 -1280 -80
WIRE -816 -32 -816 -80
WIRE -816 80 -816 32
WIRE -816 352 -880 352
WIRE -816 352 -816 80
WIRE -768 224 -768 176
WIRE -768 544 -880 544
WIRE -768 544 -768 224
WIRE -720 176 -768 176
WIRE -720 224 -768 224
WIRE -640 80 -816 80
WIRE -640 128 -640 80
WIRE -640 384 -640 272
WIRE -496 176 -560 176
WIRE -496 272 -496 176
WIRE -496 384 -640 384
WIRE -496 384 -496 352
WIRE -496 432 -496 384
WIRE -496 544 -768 544
WIRE -496 544 -496 496
WIRE -464 224 -544 224
WIRE -384 -80 -816 -80
WIRE -384 48 -384 -80
WIRE -384 224 -400 224
WIRE -384 224 -384 112
WIRE -304 -80 -384 -80
WIRE -304 32 -304 -80
WIRE -304 224 -384 224
WIRE -304 224 -304 112
WIRE -224 288 -224 -320
WIRE -160 -320 -224 -320
WIRE -160 224 -304 224
WIRE -160 224 -160 -128
WIRE -128 544 -496 544
WIRE -128 544 -128 160
WIRE -96 -368 -96 -480
WIRE -48 -368 -96 -368
WIRE -48 -320 -96 -320
WIRE -48 -80 -304 -80
WIRE -48 -32 -48 -80
WIRE -48 352 -48 48
WIRE -48 432 -48 352
WIRE -48 464 -48 432
WIRE -48 544 -128 544
WIRE -48 544 -48 528
WIRE -16 160 -128 160
WIRE -16 224 -160 224
WIRE -16 288 -224 288
WIRE -16 352 -48 352
WIRE 32 -416 32 -448
WIRE 32 -224 32 -272
WIRE 160 -448 32 -448
WIRE 160 -224 32 -224
WIRE 160 -224 160 -448
WIRE 160 -192 160 -224
WIRE 192 -480 -96 -480
WIRE 192 -320 128 -320
WIRE 192 -320 192 -480
WIRE 272 -368 112 -368
WIRE 272 -320 272 -368
WIRE 272 -192 272 -240
WIRE 272 224 208 224
WIRE 272 288 208 288
WIRE 272 288 272 224
WIRE 272 320 272 288
WIRE 336 -80 -48 -80
WIRE 336 160 208 160
WIRE 336 160 336 -80
WIRE 336 192 336 160
WIRE 336 320 272 320
WIRE 336 320 336 272
WIRE 336 352 336 320
WIRE 336 544 -48 544
WIRE 336 544 336 416
WIRE 464 -128 -160 -128
WIRE 464 224 464 -128
WIRE 464 320 464 288
WIRE 464 544 336 544
WIRE 464 544 464 400
WIRE 560 432 -48 432
WIRE 560 432 560 352
WIRE 592 544 464 544
WIRE 592 544 592 160
WIRE 656 160 592 160
WIRE 656 224 464 224
WIRE 656 288 464 288
WIRE 656 352 560 352
WIRE 944 -80 336 -80
WIRE 944 160 880 160
WIRE 944 160 944 -80
WIRE 944 224 880 224
WIRE 944 288 880 288
WIRE 944 288 944 224
WIRE 944 320 944 288
WIRE 1008 160 944 160
WIRE 1008 192 1008 160
WIRE 1008 320 944 320
WIRE 1008 320 1008 272
WIRE 1008 352 1008 320
WIRE 1008 544 592 544
WIRE 1008 544 1008 416
FLAG -1280 592 0
FLAG 160 -192 0
FLAG 272 -192 0
SYMBOL Misc\\NE555 96 256 R0
SYMATTR InstName U1
SYMBOL voltage -1072 384 R0
WINDOW 3 24 104 Invisible 0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR Value PULSE(0 5 1 1e-6 1e-6 1 0 1)
SYMATTR InstName V1
SYMBOL voltage -1280 384 R0
SYMATTR Value 5
SYMATTR SpiceLine Rser=0
SYMATTR InstName V2
SYMBOL res 320 176 R0
SYMATTR InstName R2
SYMATTR Value 1e6
SYMBOL cap 320 352 R0
SYMATTR InstName C1
SYMATTR Value 1.2e-6
SYMBOL Misc\\NE555 768 256 R0
SYMATTR InstName U2
SYMBOL res 992 176 R0
SYMATTR InstName R4
SYMATTR Value 1e6
SYMBOL cap 992 352 R0
SYMATTR InstName C2
SYMATTR Value 1.5e-6
SYMBOL cap -400 208 R90
WINDOW 0 0 32 VBottom 0
WINDOW 3 32 32 VTop 0
SYMATTR InstName C6
SYMATTR Value .1e-6
SYMBOL res -320 16 R0
SYMATTR InstName R6
SYMATTR Value 10k
SYMBOL diode -368 112 R180
WINDOW 0 43 30 Left 0
WINDOW 3 25 -6 Left 0
SYMATTR InstName D2
SYMATTR Value 1N4148
SYMBOL res 448 304 R0
SYMATTR InstName R7
SYMATTR Value 1000
SYMBOL Digital\\dflop 32 -416 R0
SYMATTR InstName A1
SYMATTR SpiceLine trise 1e-6 tfall 1e-6 vhigh 5v
SYMBOL Digital\\inv -160 -384 R0
SYMATTR InstName A2
SYMBOL Digital\\dflop -640 128 R0
SYMATTR InstName A3
SYMBOL res -896 416 R0
WINDOW 0 -40 35 Left 0
WINDOW 3 -46 62 Left 0
SYMATTR InstName R5
SYMATTR Value 100K
SYMBOL sw -880 320 M180
WINDOW 0 -55 143 Left 0
WINDOW 3 -81 109 Left 0
SYMATTR InstName S2
SYMATTR Value MYSW
SYMBOL res -512 256 R0
WINDOW 0 -43 40 Left 0
WINDOW 3 -35 71 Left 0
SYMATTR InstName R8
SYMATTR Value 1e6
SYMBOL cap -512 432 R0
WINDOW 0 -43 32 Left 0
WINDOW 3 -62 62 Left 0
SYMATTR InstName C4
SYMATTR Value 2e-6
SYMBOL res 256 -336 R0
SYMATTR InstName R9
SYMATTR Value 10k
SYMBOL voltage -1168 384 R0
SYMATTR Value PULSE(0 5 0 1e-7 1e-7 .001 .002)
SYMATTR InstName V3
SYMBOL cap -832 -32 R0
SYMATTR InstName C3
SYMATTR Value 1E-7
SYMBOL cap -64 464 R0
WINDOW 0 36 34 Left 0
WINDOW 3 24 60 Left 0
SYMATTR InstName C5
SYMATTR Value 1E-7
SYMBOL res -64 -48 R0
WINDOW 0 -53 35 Left 0
WINDOW 3 -67 62 Left 0
SYMATTR InstName R1
SYMATTR Value 100K
TEXT -1178 -160 Left 0 !.tran 0 3s 0
TEXT -1184 -128 Left 0 !.model MYSW SW(Ron=1 Roff=1Meg Vt=.5 Vh=-.4)
John Fields
On Fri, 09 Jun 2006 17:19:06 -0500, John Fields
+12V>-+-------+
| | U3B
O [0.1µF] 4027
| | 9+-------+15
| 13| |12 |
| |10| | |
|11| _ |14 |
+--|K1 Q1|---+ GND
GND |
|K | | U1 |8 |
| | | 2|_ Vcc _|4 |
| | 6| |3 1| \ 2
| | 7|_ |5 | /
| +--O|D VC|----+
| +| | GND | |
| | |1 |
| | U4 | |
| [1MR] +---+---+ |
| | |_ Vcc _|4 |
| | |3 | \
| |_ | | /
+--O|D VC|----+
+| | GND | |
E
ehsjr
Jason.
In addition to John's reply, another change is needed:
you're not driving Q1 hard enough. Lower the value
of R2 from 10K to 1K.
Ed
Jason S
Ed
Noted. Thanks Ed =)
Jason S
Thanks guys heaps. You been a great help.
I haven't had a chance yet to try your schematic John (Petrus and ehsjr, I
have noted your observations and advice as well), but I'll let you know as
soon as I've totally rewired my breadboard...ugh.
However, do I really need to add another IC to my board (the 2nd 555)? This
board has to be as small as possible... I didn't think I'd need so much
electronics to do this simple task. Maybe 1x 556 (dual 555 IC) instead of
2x 555 would save a little more space??
By the way - in relation to the way I configured the monostable.... is it
still a bad thing to want to be able to trigger the monostable at power on
(ignoring the reed switch for arguments sake)? Assume pins 1 and 8 were
connected directly to the supply rails... so when power is turned on, the
monostable triggers automatically (due to C2). I understand the correct
method of triggering pin 2 with a negative pulse, but then I would need a
separate circuit to achieve that as well - the negative pulse. That is the
only reason why I connected the reed relay the way I did - When the magnet
comes into contact with the reed, it triggers the 555, doesn't matter how
long the reed is in contact with the magnet for. In my circuit, if I made
it so that the reed switch triggers pin 2, the 555 would freeze (on 'high')
because the motor would have turned off and stopped right in front of the
magnet indefinately. I was just wondering that's all.
The two 15V zener diodes across the motor opposite each other is critical
yeah? Is my Q1 transistor overheating because these are absent? Or because
of the motor reactivating too soon before the relay switches over??? The Q1
is rated 0.8A.
P.S: John, I really appreciate your schematics... makes it a lot easier to
understand what you are talking about =).
Ta
Jason.
Jason S
This board has to be as small as possible... I didn't think I'd need so
much electronics to do this simple task. Maybe 1x 556 (dual 555 IC)
instead of 2x 555 would save a little more space??
the only reason why I connected the reed relay the way I did - When the
magnet comes into contact with the reed, it triggers the 555, doesn't
matter how long the reed is in contact with the magnet for. In my
circuit, if I made it so that the reed switch triggers pin 2, the 555
would freeze (on 'high') because the motor would have turned off and
stopped right in front of the magnet indefinately. I was just wondering
that's all.
because of the motor reactivating too soon before the relay switches
over??? The Q1 is rated 0.8A.
to understand what you are talking about =).
Ta
Jason.
*** Further to this, I have redone my schematic. Please check if everything
is correct as I may have missed something or misunderstood a bit here n
there.
Try this direct link :
http://www.jason3712.zoomshare.com/...pe_editable.css&css=/lib/style/type_album.css
.... or find it manually by going to http://www.jason3712.zoomshare.com/
then clicking 'PHOTOS', 'Electronics', and clicking top (most recent) image,
"schemtaic_SL_v2".
I am yet to rewire my breadboard.
Regards,
Jason.
Alan B
True, and not yet. :)
But, on Windows, Paint Shop Pro can convert image formats, and on Linux,
The Gimp, so it's not all that hard.
http://www.abiengr.com/~sysop/Share/PSP412.EXE - it's shareware, but very
old, but very good for what it does. :)
Irfan V. 3.80 for Windows does the trick nicely. I don't like the newer
versions. And, um, thanks for the info about .gif vs. .jpg. Now it's off
to the forest to take some photos of hot babes!
John Fields
The second 555 isn't necessary. After thinking about it for a
while, Petrus' suggestion to use unused gates to get the delay
turned out to be a good one, so that's what I did. I've posted a
new schematic for you on abse which has that change (as well as
others) on it. After looking the schematic over, if you need a
circuit description I'll be happy to post one here.
And _stays_ triggered, so its output can never go low, U2-2 can
never go high, and the motor will never be able to turn!
For a 555 to operate properly, the signal on pin 2 must go more
negative than 1/3Vcc and then go more positive than 2/3Vcc before
the the output timeout period elapses.
No, you wouldn't, all that would need to happen is that the circuit
be reconfigured. See my schematic.
That is the
That's not true. Assuming a normally open reed switch, the way you
have it wired now keeps the 555's input low, which keeps its output
high until the magnet makes the switch, then the switch closes and
forces the outout of the 555 low until a switch bounce cause it to
start timing out again. That's one of the reasons for the source of
your problems.
Maybe not critical, but you need them in there to clamp any
transients caused by a change of current in the inductance of the
motor.
is rated 0.8A.
More than likely because you're not providing enough base current to
drive the transistor into saturation. That's why Ed suggested that
you change R2 to 1K. The problem you may have with that is that
4000 series CMOS can't supply much current without going out of
rail-to-rail. I've paralleled three of the 4069's inverters in
order to circumvent that, and you should be able to drive the
transistor nicely with that "buffer"
Jason S
--------- Hi John, I don't see the new schematic on adse =( Remember how
you couldn't see mine? Looks like the same thing is happening. Please, I
would like to see it =)
If I could get away without the need for an additional IC, I'd be happy.
But if I need it I need it... but I'll probably end up somehow wiring up a
556 rather than two separate 555's. That'd be alright wouldn't it?
motor.
John, please confirm the correct wiring of these zeners on my schematic if
your new schematic doesn't include this section of the circuit. I'm not
100% if I understood what you meant by, "connect two 15V Zener diodes in
series opposition across the motor".
Jason.
John Fields
OK, I've emailed it to you.
If you don't have access to abse it's probably because your ISP
doesn't carry abse. If you want it, let them know and maybe they'll
start carrying it.
BTW, I'm working on a version of the circuit with _no_ 555s which
looks pretty good. I'll post it to abse and email you a schematic
when I'm done. Sometime today, I think.
John Fields
start carrying it.
Better than that, an LTSPICE simulation follows that uses only two
chips for the logic, a "D" type flip-flop and a NOR. I used a
MOSFET bridge instead of a relay for the motor rotation reversal,
but if you want to use a relay you can hook it up like you've shown
on your schematic. Same thing for the power ON-OFF to the motor.
Version 4
SHEET 1 2564 1056
WIRE -2304 112 -2304 -624
WIRE -2304 480 -2304 112
WIRE -2304 624 -2304 560
WIRE -2304 672 -2304 624
WIRE -2192 480 -2192 224
WIRE -2192 624 -2304 624
WIRE -2192 624 -2192 560
WIRE -2096 112 -2304 112
WIRE -2096 480 -2096 320
WIRE -2096 624 -2192 624
WIRE -2096 624 -2096 560
WIRE -2000 624 -2096 624
WIRE -2000 624 -2000 368
WIRE -1952 320 -2096 320
WIRE -1952 368 -2000 368
WIRE -1904 224 -2192 224
WIRE -1904 304 -1904 224
WIRE -1904 432 -1904 384
WIRE -1904 512 -1904 432
WIRE -1904 624 -2000 624
WIRE -1904 624 -1904 592
WIRE -1840 112 -2032 112
WIRE -1840 432 -1904 432
WIRE -1840 432 -1840 112
WIRE -1792 304 -1792 256
WIRE -1792 624 -1904 624
WIRE -1792 624 -1792 304
WIRE -1744 256 -1792 256
WIRE -1744 304 -1792 304
WIRE -1664 112 -1840 112
WIRE -1664 208 -1664 112
WIRE -1664 464 -1664 352
WIRE -1664 512 -1664 464
WIRE -1664 624 -1792 624
WIRE -1664 624 -1664 576
WIRE -1632 464 -1664 464
WIRE -1520 144 -1520 112
WIRE -1520 256 -1584 256
WIRE -1520 256 -1520 208
WIRE -1520 464 -1552 464
WIRE -1520 464 -1520 256
WIRE -1408 112 -1520 112
WIRE -1408 464 -1408 112
WIRE -1408 512 -1408 464
WIRE -1408 624 -1664 624
WIRE -1408 624 -1408 576
WIRE -1328 464 -1408 464
WIRE -1328 496 -1328 464
WIRE -1328 624 -1408 624
WIRE -1328 624 -1328 576
WIRE -1184 112 -1408 112
WIRE -1184 208 -1184 112
WIRE -1184 304 -1184 272
WIRE -1184 368 -1184 336
WIRE -1184 480 -1184 432
WIRE -1184 512 -1184 480
WIRE -1184 624 -1328 624
WIRE -1184 624 -1184 576
WIRE -1152 208 -1184 208
WIRE -1152 272 -1184 272
WIRE -1152 368 -1184 368
WIRE -1152 432 -1184 432
WIRE -1152 480 -1184 480
WIRE -1040 -464 -1040 -592
WIRE -1040 256 -1088 256
WIRE -1040 256 -1040 -416
WIRE -1040 288 -1184 336
WIRE -1040 288 -1040 256
WIRE -1040 336 -1184 304
WIRE -1040 416 -1088 416
WIRE -1040 416 -1040 336
WIRE -1040 480 -1072 480
WIRE -1040 480 -1040 416
WIRE -992 -464 -1040 -464
WIRE -992 -416 -1040 -416
WIRE -912 -512 -912 -560
WIRE -912 -320 -912 -368
WIRE -912 -224 -912 -320
WIRE -864 112 -1184 112
WIRE -864 208 -864 112
WIRE -864 304 -864 272
WIRE -864 368 -864 336
WIRE -864 480 -864 432
WIRE -864 512 -864 480
WIRE -864 624 -1184 624
WIRE -864 624 -864 576
WIRE -832 208 -864 208
WIRE -832 272 -864 272
WIRE -832 368 -864 368
WIRE -832 432 -864 432
WIRE -832 480 -864 480
WIRE -784 -560 -912 -560
WIRE -784 -320 -912 -320
WIRE -784 -320 -784 -560
WIRE -736 -592 -1040 -592
WIRE -736 -416 -816 -416
WIRE -736 -416 -736 -592
WIRE -736 -176 -736 -416
WIRE -736 80 -736 -176
WIRE -720 256 -768 256
WIRE -720 288 -864 336
WIRE -720 288 -720 256
WIRE -720 336 -864 304
WIRE -720 416 -768 416
WIRE -720 416 -720 336
WIRE -720 480 -752 480
WIRE -720 480 -720 416
WIRE -672 -176 -736 -176
WIRE -672 80 -736 80
WIRE -624 -192 -624 -256
WIRE -624 -48 -624 -96
WIRE -624 0 -624 -48
WIRE -624 144 -624 96
WIRE -528 256 -720 256
WIRE -512 -48 -624 -48
WIRE -480 -624 -2304 -624
WIRE -480 -256 -624 -256
WIRE -480 -256 -480 -624
WIRE -480 144 -624 144
WIRE -480 176 -480 144
WIRE -480 368 -480 272
WIRE -336 -256 -480 -256
WIRE -336 -192 -336 -256
WIRE -336 -48 -432 -48
WIRE -336 -48 -336 -96
WIRE -336 0 -336 -48
WIRE -336 144 -480 144
WIRE -336 144 -336 96
WIRE -240 -464 -832 -464
WIRE -240 -176 -288 -176
WIRE -240 -176 -240 -464
WIRE -240 80 -288 80
WIRE -240 80 -240 -176
FLAG -2304 672 0
FLAG -912 -224 0
FLAG -480 368 0
SYMBOL voltage -2096 464 R0
SYMATTR Value PULSE(0 5 .1 1e-6 1e-6 .01 2s)
SYMATTR InstName V1
SYMBOL voltage -2304 464 R0
SYMATTR Value 12
SYMATTR InstName V2
SYMBOL res -1056 464 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName R2
SYMATTR Value 1e6
SYMBOL cap -1200 512 R0
SYMATTR InstName C1
SYMATTR Value .4e-6
SYMBOL cap -1536 144 R0
SYMATTR InstName C6
SYMATTR Value .1e-6
SYMBOL res -1344 480 R0
SYMATTR InstName R6
SYMATTR Value 10k
SYMBOL diode -1392 576 R180
SYMATTR InstName D2
SYMBOL Digital\\dflop -1664 208 R0
SYMATTR InstName A3
SYMATTR SpiceLine trise 1e-6 tfall 1e-6 vhigh 12v
SYMBOL res -1920 496 R0
SYMATTR InstName R5
SYMATTR Value 100K
SYMBOL sw -1904 400 M180
WINDOW 0 -51 9 Left 0
WINDOW 3 -76 -15 Left 0
SYMATTR InstName S2
SYMATTR Value MYSW
SYMBOL res -1536 448 R90
SYMATTR InstName R8
SYMATTR Value 1e6
SYMBOL cap -1680 512 R0
SYMATTR InstName C4
SYMATTR Value .3e-6
SYMBOL voltage -2192 464 R0
SYMATTR Value PULSE(0 12 0 1e-6 1e-6 1e-3 2e-3)
SYMATTR InstName V3
SYMBOL cap -2032 96 R90
SYMATTR InstName C3
SYMATTR Value 1E-7
SYMBOL Digital\\dflop -912 -512 R0
SYMATTR InstName A1
SYMATTR SpiceLine trise 1e-6 tfall 1e-6 vhigh 12V
SYMBOL Digital\\or -1120 176 R0
WINDOW 0 -10 110 Left 0
SYMATTR InstName A9
SYMBOL res -736 464 R90
SYMATTR InstName R1
SYMATTR Value 1e6
SYMBOL cap -880 512 R0
SYMATTR InstName C5
SYMATTR Value .5e-6
SYMBOL Digital\\or -800 176 R0
WINDOW 0 -10 112 Left 0
SYMATTR InstName A2
SYMBOL Digital\\or -800 336 R0
SYMATTR InstName A4
SYMBOL Digital\\or -1120 336 R0
SYMATTR InstName A10
SYMBOL pmos -288 -96 R180
SYMATTR InstName M3
SYMATTR Value FDS6575
SYMBOL pmos -672 -96 M180
SYMATTR InstName M1
SYMBOL nmos -672 0 R0
SYMATTR InstName M5
SYMATTR Value FDS6680A
SYMBOL nmos -288 0 M0
SYMATTR InstName M6
SYMBOL nmos -528 176 R0
SYMATTR InstName M2
SYMBOL ind -528 -32 R270
WINDOW 0 32 56 VTop 0
WINDOW 3 5 56 VBottom 0
SYMATTR InstName L1
SYMATTR Value .1
SYMATTR SpiceLine Rser=10
TEXT -2258 680 Left 0 !.tran 0 30s 0
TEXT -2280 648 Left 0 !.model MYSW SW(Ron=1 Roff=1Meg Vt=.5 Vh=-.4)
TEXT -2192 208 Left 0 ;BOUNCE / NOISE
TEXT -2096 304 Left 0 ;REED SWITCH
TEXT -1792 184 Left 0 ;DEBOUNCE
TEXT -1176 152 Left 0 ;SPINDOWN
TEXT -1152 176 Left 0 ;TIMER
TEXT -848 152 Left 0 ;POWER
TEXT -840 176 Left 0 ;TIMER
TEXT -1024 -536 Left 0 ;FWD/REV
Jason S
start carrying it.
[snip]
John Fields
Professional Circuit Designer
Hi again John,
Thanks, I received your email with your PDF attachment. I have also added
this to my website so everybody else can see what you have posted to me, if
that's ok.
Click this link to view the schematic John Fields emailed to me :
http://www.jason3712.zoomshare.com/...pe_editable.css&css=/lib/style/type_album.css).
I rewired my breadboard and the attached circuit works quite well, although
I couldn't hook up the gearhead motor because I broke one of its terminals
=S ... I'll have to pull it apart and resolder it. Besides, I don't have
any 15V zeners on me at the moment, so I don't want to pop another BC338!
But at least I can tell what is happening by the 3 LED's, "Motor On",
"Direction A" and "Direction B". So it appears now there is that extra
delay before the motor turns back on.
I've noticed a potential problem though!!! You know how this thing pans 180
degrees and then changes direction shortly after the reed switch is
magnetized? This thing would break on me if it was left the way it is (not
the circuit, but the outer structure because it's not designed to spin
beyond 180 degrees).
- I'll give you an example:
Imagine the motor is turning in Direction "A", and the reed switch just made
contact with the magnet. Then I shut down the whole circuit intentionally
(at this stage, it has already panned 180 degrees, which is the max). If
you then turn the circuit back on, *sometimes* the motor starts to spin in
the same direction (A) it was before - when it should be turning the
opposite direction (B) straight away. So somehow the circuit will need to
know that it reached the end from the previous time and should be turning in
the correct direction. I'm not sure how this will need to be hooked up, but
maybe a second reed switch is needed (one for each direction)???
Other than that it seems to be working fine. I can't wait to see your next
version John.... no 555!
Regards
Jason.
John Fields
Jason S
John!
Thanks for the once-again modified schematic.
Fantastic to see less IC's ... from three down to only one single IC now,
the 74HC02 NOR gate! As you know, IC's take a lot of room on a board, and
my board needs to be as small as possible.
I haven't got some of the parts readily available to modify my breadboard
prototype, but when I get my hands on them (within the next couple of days)
I will try it out and see what happens! I'll get back to you to let you
know how I went. Fingers crossed it won't need any more mods =)
I will include your mod on my website incase anyone wants to see it (for
those who can't access it via ABSE like I can't).
Jason.
Jason S
Hi John,
I built your latest schematic on my breadboard. Works really well, except
for one thing.... There is no 1 sec delay for the motor before the relay
switches over. So what it's doing is turning off the motor and switching
relay contacts at the same time, then half a second later the motor turns
back on.
Regards
Jason.
John Fields
Hi John,
back on.
Good!, that's how it's supposed to work. :)
The reason the relay switches over when the motor stops is because
there's no reason for it not to and it saves a timer.
Think about it... once power to the motor is cut off, all you need
is the delay for the motor to stop turning before you supply power
to the motor again, so when the direction-reversing relay switches
over is immaterial.
If you need some extra time before power is again applied to the
motor just adjust R10.
