Sir Mel . . . . .
You already had the answer on your other post on the very tail end of another like thread topic.
My vote is also for it being an input line surge power thermistor . . .as per near center page 30 of the below reference.
Product Catalog Referencing :
http://pdf.datasheetarchive.com/indexerfiles/Datasheet-025/DSA00436541.pdf
Upon initial power up, it provides 60 ohms of isolaton of the main filter cap(s) until they rapidly charge up and take on their initial charge, while the unit is rapidly dropping in resistive value as it heats up, and ends up at about 1 ohm, and at that value, is then capable of passing up to 2 amps thru the supply.
You might also confirm, by its proximity of placement in the power supply portion of that board, and its being close to the AC line input line , or the main filters.
Also look at the items assigned designation, that it is being placed nearby, with the PCB silk screening.
73's de Edd
