Hello
I am trying to make a circuit powered by a 18650 lithium ion battery that will delay power on to a '3 watt bluetooth module' for connection to speakers
The Lithium Ion Battery when fully charged is around 3.7 volts which powers the bluetooth module reliably when connected directly
The bluetooth module can be found on aliexpress if you search for '3W bluetooth module' and sort by orders
I could post the link but it's really messy and long. I can post it if requested in a separate post
I've been looking at LM555 circuits but I want something that once the switch is closed it will delay power on for about three minutes and stay powered on for 105 minutes to forever, but will switch off immediately if the switch is opened.
I can connect modules together to build things but am getting confused by all the different types 555 of circuits and styles in which they can be used
I tried reading through all the circuits on this page but wanted something other than an 'oscillator' circuit
http://home.cogeco.ca/~rpaisley4/LM555.html#2
Would another type of timer circuit be better as I need the assembly to be really small?
Would this be the circuit to try first ?
http://www.learningaboutelectronics.com/Articles/555-timer-delay-before-turn-on-circuit.php
Thanks for your time for reading
and any help you can give
Rob
Rob
