Experimenting with "vintage" radio circuits I find myself in need of various high voltage supplies,typically in the range of 250 to 650 VDC.
I have several industrial type transformers designed to boost 120 to 220 VAC and, 220-440 VAC, at several amps. These were used for running light , lighting and small single phase motors from a 3 phase motor control center. Physically they are 6X6X8" in size. I have quite a few.
I've been able to build unregulated supplies by wiring the primaries in series and secondaries in parallel combination. Resulting in 120V input, 220/440/880 output. With rectification and filtering I can get (1.414X) : 311 ,622, and 1244 VDC unregulated at several amperes.
What I would like to build is a series pass element regulator circuit to yield: 100V, 250-275, 350-375.400-775, etc, variable output at 0.5 to 1 ampere.
I found a circuit using a Supertex LR8 High Input Voltage Adjustable # terminal Linear Regulator and a TK9J90E MOSFET as a pass element. I'm not sure if these parts are still obtainable (obsolete), but I need something , if not similar.
With 311,622,1244 VDC fixed, a lot of voltage drop would be needed to occur requiring a lot of heat sinking. Never the less my quest, if practical, is to find a circuit to accomplish this.
Has anyone else tried this? Are there more practical components /circuit designs available?
Thanks,
Eddie
Thanks,
Eddie
