I have a Mentor Drive 6MS200, Single Quad, for a max 200kw DC motor, Max continuous rating AC 460, 3 phase on 380 V that is powering the motor of twin screw extruder.
I am having the following problem:
Upon start at lowest possible RPM, huge sparks occur on the carbon brushes and an "over current" error is displayed on the mentor drive.
I have meanwhile replaced the brushes, but as winter and rain is upon us, the problem seems to become worse.
What seem to help, is warming the room and then starting the drive - Once ON, there are no apparant issues.
However, it has rained a lot recently, and it could be more moisutre in the control room.
Also, I don't have an oscilloscope, which does scare me to attach to the unit. As I mentioned the moment power starts, and overcurent occurs instantly, so I don't think I would see anything!!!
I am a Mechanical Enginer with basic electircal background. I know my way around 3phase AC motors and the use of the Voltmeter and understand the dangers at this high power levels.
Unfortunately, Mentor is not cooperative and is simply saying " just replace everything".
Any ideas what the problem could be? There are the 6 trysystors, inside the Mentor drive as well as Field Controller FXM2 by KTK Newtonw Limited.
In addition there are some resistor network and the potentionmeter for the speed setting with a tachometer for speed measurement on the shaft of the motor in a closed loop feedback control system.
I would appreciate any feedback and help and would gladly compensate for it.
Sincerely,
Allan
Sincerely,
Allan
