Okay. In your first schematic (reproduced below) the 470 Ω resistor provides current-limiting for the series-connected LED between +9 V and GND. The LED illuminates the Photo-Transistor (PT) which then conducts current from +9 V through the variable 100 kΩ resistor from the PT collector to the PT emitter to GND. This causes the collector voltage of PT to vary from +9 V when the PT is NOT illuminated down to almost +0 V when PT is fully illuminated by the LED.
A sufficiently large positive voltage on the collector of PT (greater than about +2 V), which will occur when the light from the LED is blocked or interrupted, will forward-bias the base-emitter junction of the 2N2222 transistor, causing it to conduct from +9 V through its collector to its emitter and through the 10 kΩ resistor in its emitter then through the gate-to-cathode junction to GND of the SCR, which should trigger the SCR to conduct.
If there is a steady positive voltage on the anode of the SCR with respect to GND, the SCR will latch on and stay on if there was sufficient gate current supplied by conduction of the 2N2222 to trigger it. This is NOT a good way to operate this circuit. Presumably you want the SCR to turn ON when the the light path between the LED and the PT is blocked, and to turn OFF when the PT is illuminated by the LED. This won't happen with DC applied to the anode of the SCR. You need a low-voltage power-line operated AC voltage source, typically provided by a small step-down transformer, to power your indicator light and to commutate the SCR, causing it to cease conduction when its anode goes negative with respect to GND each half-cycle of the AC power source.
So, get yourself what is commonly called a "filament transformer" providing about 6.3 VAC with a few hundred milliamperes current capability. Current rating is not critical since all you want to drive is a small LED indicator light for now. Voltage rating isn't critical as long as it is large enough to turn on your LED. Next from the following description, draw up a proper schematic that you can construct from: Connect one wire from the transformer low-voltage secondary winding to GND. Connect the other wire from the low-voltage secondary winding to a 470 Ω, 1/4-watt, current-limiting resistor. Connect the other end of the 470 Ω resistor to the anode of an LED of your choosing. Connect the cathode of the LED to the arrow labeled OUTPUT in the schematic above, which is the anode of the SCR. Plug in the transformer to the power line, connect the 9 V power source, and you should be good to go.
The above circuit is a very poor design. If the 100 kΩ variable resistor is set to too low a value, it may be possible to burn out the PT under strong illumination by the LED. This variable resistor limits PT collector current under strong illumination. Setting it to zero ohms value is not a good idea.
Good luck with your "monkey see, monkey do" approach to electronics. Perhaps you would be more comfortable at instructables.com?
