davenn
So I ended up going with a rail-to-rail op amp (OPA171AIDR) and for the most part it has been working great.
but you are not using it in a rail-to-rail setting ... you are showing just a single rail PSU
I also really don't like the use of a zener for this situation
regulation is going to be horrible. The supply voltage from the zener is going to fluctuate
as the Op-Amp 's output/load varies
I think it was Harald that suggested you use a 7812 V-reg some posts back
what is the load on the analog output ?
Dave
