Hi guys,
I am currently using a parallax propeller micro controller to generate a signal.
I am using a ADC to create a 0-5v signal, and an op-amp to convert this into a 0-10v signal. I am experiencing a problem with it. Everything works fine until I go below 1.9v on the input of the op amp... at this point, the output of the op-amp pegs at 3.93v. When I supply 0 volts to the input, it is also stuck at 3.93v for the output of the op amp. Above 1.9v, and the op-amp works perfectly fine and has a gain of 2x which is what I want.
I'm thinking it has something to do with the op-amp I'm using, and the offset gain associated with this op-amp, but honestly I don't really understand it (I'm still somewhat of a newb with electronics). If I could provide 0 volts to the input of the op-amp, and have it just be closer to 0 (no higher than 0.5 volts) then this would be satisfactory. I attached a schematic which has the parts I'm using as well.
Thanks and any help is greatly appreciated!
