Hello there.
I found a circuit guide to make a LDR night light. I have got a question :
the 10K resistor reduces the brightness of LED quite remarkable. I tested with lower resistors , even less than 1K resistors. Brightness increases as resistor lowers , but the problem is that it also reduces sensitivity of LDR. I mean If I use a 1K resistor , for instance , then the LDR needs too much brightness of light to turn the LED off.
What to do ?
* I don't use a resistor between LED and power source (in the picture which is marked as "If needed")
* I use 7-millimeter LDR . All other specifications are similar to the photo of circuit I attached
What to do ?
