Okay, so to give a little background, I have a couple 4-125A tetrodes laying around as I've had a bit of a collector's hobby with collecting various tubes.
The 4-125A is the smallest of a series of air-cooled RF transmitter tetrodes, the others in the series being the 4-400A and 4-1000A. The 4-125A is rated at 125W dissipation, 400 and 1000W respectively.
So, I've decided to develop them into a stereo hi-fi amp. Probably not the smartest thing to do with RF tetrodes, but as they're gathering dust on a shelf, I figured I may as well tinker with them. AF builds with them have been done, although information on them is damn-near nonexistent so I'm working a build from scratch.
I already have a supply capable of supplying 2kV to the plates, but the question of an output transformer comes into play. I could wind my own (I have all the equations and what-not to properly calculate), but the immense amount of winding is a bit of a discouraging factor, not to mention I'd have to rip apart existing trafos for the laminations.
Now, here's my issue:
I used the datasheet to determine that a good starting point (and good in terms of power supply) would be to supply each of the two tubes with a 2kV plate voltage at 200mA, biasing at -100V per the data sheet. If I have any of the math correct, that would give a plate impedance of about 10K nominal.
Problem is, the Hammond output transformer I found with a 10K primary (which is in itself a costly and hefty beast) is only rated to 90mA safe. I'd be fine if I were having to put 120mA across it, but 200mA is asking for a smoke machine.
Point being, I can't use it.
So, what should my next step be? I need help interpreting the datasheet to determine appropriate points.
Here is the link to the data sheet:
4-125A Datasheet
4-125A Datasheet
