hi
i want to build a dc to dc converter that should be able to give me output volts ranging from 1.5 to 28 volts .. my input will always be 31 volts from a smps adapter..
i earlier used lm317 but that was wasting too much power..so need one using buck converter..
i have chosen LM2596 ... so her are my questions
1: is there anything better then this ? more efficient and not more complex then it..
2: i have found a circuit for it in the TI DS for this ic which is using the -ADJ or adjustable version to make adjustable buck converter..
but that ckt has no pot or any mean to adjust the output voltage at whim.. so by the adjustable feature of that ic as opposed to fixed output ic i can get that it needs to be designed for only on output.. ? for another output i will have to redesign it..?am i right ?
this is my main concern.. how do i overcome it
my max current will be 1.5 amp..
i want to make something like this
http://www.suntekstore.com/goods-14...tep-down_adjustable_power_supply_module_.html
thanks
thanks
