Disconnect the wires leading from the counter to the 7 segment decoder.
Ground all the inputs to the 7 segment decoder. Does it display 0?
Take each input to logic high one at a time (just leaving them floating -- i.e. connected to nothing -- should work for testing). The decoder should give you the values 1, 2, 4, and 8.
then measure the voltage on the output of the counter. Are they all at 0V after you hit reset? Which pins are you testing (i.e. which pins do you believe are the outputs).
