i live on a caribbean island and clouds are expensive!!! believe it or not a kwh of electric at 120v is US$.50 because of the laws here i have hooked up pv solar arrays to inverters and have run directly to the compressor of a/c units. no batteries and i'm still on grid. all of the electric i produce is consumed by the ac unit cause they use more then the panels produce ( i leave the unit at the lowest setting and the compressor never stops running) and the solar/inverter circuit is not complete unless the ac unit is on. i tie the solar power into the compressor and the circuit is only complete when the a/c contactor is closed and the compressor is running. i only run the ac during the day and the house gets nice and cold and retains it will into the next morning. i manually turn my ac off late in the day, my ac bill has been reduced in a major fashion!!! every time a cloud goes when the ac is running i'm pulling loads from the grid. that costs me $3 / hour and adds up fast. the house actually gets to cold but when the sun is out it's almost free - so what the heck. if i'm home and the big black cloud goes over i manually turn the a/c off and back on when the sun comes out. what a nuisance!!!! i was hoping i could hire to do some work for me. i need a design and build. read amps from a pv solar array and if the circuit is producing above a preset level of amps then keep the relay for the ac circuit closed. if the amps fall below that preset level then open the relay. then with a timer delay check the amps again in 3 minutes and close if we have enough or open if it’s below the preset level of amps
the timer will always be 3 minutes after each opening or closing. i’m running a compressor and don’t want start / stops all the time. the timer could continuously read after the 3 minutes has elapsed.
the preset level amps (120v 60hz) has to be adjustable. i may want to run it if i’m getting 5 amps or perhaps 10 amps. i want the ability to choose that level.
i have more details but i think you get the general idea of what i’m looking for. in the beginning i need one then i’ll need six more and then who knows how many. i'm sure there will be a few issues we need to work through.
to make matters worse i have three guest houses which i have identical systems and a few friends already have similar systems installed. those clouds are expensive!!!!
i understand electric in a basic way and have no education in electricity but i can do 90% of any wiring i need. this is well above me.
thanks,
henry barbera
thanks,
henry barbera
