Need help finding resistance for 12V to get 300 mA.
  • Thread starter Ricky Spartacus
  • Start date
Ricky Spartacus
Assuming an ignition control module's trigger input can't exceed 300 mA,
what should resistor value to trigger this device with 12V. I've triggered
this device with 1.5V cell and works fine but not sure how to do the math
regarding the question above. I lost the website that has a current
calculator.
Ric
Brian
calculator.
Ric
Why not have your own program that can do that (plus a lot more), for less
than the price of a good technical book. See what I mean at
http://www.fncwired.com
It has a demo that you can download.
R = E / I
P = E * I
R = resistor value
E = volts
I = current
P = Power rating needed for resistor
12 / .3 = 40 ohms
12 * .3 = 3.6 watts
Hope this helps,
Brian
Rich Grise
Can you post the specs on that module? I can't imagine something
designed for a car that would be damaged with up to 12 volts at
the input. The spec _might_ be saying that the input won't load
your driver circuit more than 300 mA. I don't know if anybody's
ever seen a spec for an input where the drive to that input has
to be current-limited.
Thanks,
Rich
