A much better white noise source can be made with lots of stages of
jellybean shift register, with two taps XOR'd back to the data input,
with an external clock. The MM5837 is only 17 stages tapped at 14 so it
has an audibly repeating pattern.
The ARG (Audio Reference Generator) we used to make used 33 stages of
SR with taps at 20 and 33 fed back. This gives white noise that does
not audibly repeat (I forget the period, it was minutes or hours.) The
clock was I think about 100 kHz.
The noise generator in Dolby Stereo alignment equipment uses 49 stages
with taps at 44 and 49 fed back. With a 766 kHz clock, the repeat time
is 204,000 hours so you would be *very* hard pressed to hear a pattern.
I have often idly wondered how the designer comes up with the taps for
this service.
Cheers, Clive Tobin
www.tobincinemasystems.com
