I'm working on a project where I need to measure 30 voltages simultaneously inside of a sealed 16.5" x 20" enclosure. Since the measuring equipment must remain outside of the enclosure, I need some kind of plug with 60 terminals that mounts on the side of the enclosure and will go through the panel to the individual positive and negative ends of each unit that needs measurement.
At first I was thinking something along the lines of this:
http://www.mcmaster.com/#terminal-blocks/=py3udf
Fitting 30 circuits with these, however, will take up too big of a footprint.
My next thought was go smaller with some kind of standard pin and socket connector but was having a hard time imagining how I would get each pin to act as a seperate circuit.
I feel like there is an easy part out there that will fit my application here, I just don't know what to look for (ME background, not very good with electronics). Any assistance from you guys would be extremely helpful.
The panel thickness is 11mm btw.
