I am in need of a test fixture for an automotive door lock actuator.
I have a door lock actuator using a tiny 12v DC electric motor (Mabuchi FC-280PC-22125) -- this motor has 5.56A stall current.
I have sourced a new electric motor and want to test it thoroughly in the actuator to make sure it doesnt also die in short order, like the OEM version does.
To do that, I want to build a test set up which will cycle the motor until the built in limit switch indicates full lock. Then wait 2 seconds, then reverse polarity until the unlock limit switch is triggered. The lock and unlock trigger switches send current to inputs in the wire harness connecting to the actuator. So, for the purposes of this project, they will be translated into current to indicate when the actuator has locked, and when it has unlocked.
I would love for this set up to be powered off a standard 120v AC wall outlet, but if thats too difficult a standard 12v car battery will suffice.
I also want a counter that is keeping track of how many locks and unlocks. If that is too difficult, I guess I could just time it and assume the average cycle time is X seconds and get my total cycles from there.
Is there such a thing readily available, or would this need to be built from scratch?
I appreciate any and all help with this project.
Jeff
[email protected]
Jeff
[email protected]
