christopher@NOSPAMoldtemecula.com
I am working on a hobby project and would like to find a "single chip"
solution or "circuit" for a sample & hold frequency to voltage
converter with a no drift output.
I have a generated audio range of 50 Hz to 300 Hz
I would like to correlate the Output voltage range as:
5v @ 50 Hz - to - 8v @ 300 Hz
A new update or sample pulse would be once every 10 minutes. The
output voltage must hold solid, in other words absolutely drift/decay
free between 10 minute intervals.
I tried a 1 Meg resistor and a 1 uf film capacitor on a TL082 OP Amp
input with the unacceptable output voltage decay shown below.
Decay Time
5.58v 12:33
5.57v 12:36
5.56v 12:41
5.55v 12:46
5.54v 12:53
The ideal chip would be 8 pin and drift free on the Output. It needs
to operate from a single 9 volt battery, so minimum current drain is
important.
Any chip or circuit recommendation is appreciated.
Thank you for your insight and sharing your knowledge
Christopher
Temecula CA.USA
http://www.oldtemecula.com
Decay Time
5.58v 12:33
5.57v 12:36
5.56v 12:41
5.55v 12:46
5.54v 12:53
important.
Christopher
Temecula CA.USA
