Need 1.5" LCD for Finepix A303
mkaiser
My A303 has a dead LCD screen. The camera still works, but of cours
it's much harder w/out the on-screen menus, etc. Other posts seem t
point to buying non-working cameras off e-bay for parts. Does anyon
know if Fuji sells parts, or any other way to avoid the $96 - $13
repair fees I've found on the Internet? Thanks!
Mark Kaise
mike
mkaiser said:
My A303 has a dead LCD screen. The camera still works, but of course
it's much harder w/out the on-screen menus, etc. Other posts seem to
point to buying non-working cameras off e-bay for parts. Does anyone
know if Fuji sells parts, or any other way to avoid the $96 - $137
Mark Kaiser
Are you sure the LCD is dead? Sometimes it's just the backlight that's
much easier to deal with. Take a penlight with a small beam and shine
it directly in contact with the LCD. You should be able to barely make
out the screen in adjacent areas if the lcd is working.
There's also the possibility of a manufacturing defect like missing
solder on some pins that took this long to corrode and open up.
I chased my tail over camera data corruption for a week before I
discovered missing solder on joints on the CF socket.
Connector snapped open?
Worth a shot.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
spudnuty
Well do like Mike says and check the LCD out. Also when you open the
camera up check out the flex that leads to the LCD (a high power
magnifier helps here) You're looking for corrosion and open traces and
as above bad solder joints.
I've had good luck swapping parts out of cameras I bought on eBay. An
A303 just went for $41.
Richard
