Radium
Hi:
Below is an example of my "parallel hz"
http://img56.imageshack.us/img56/2427/clocksignalexample8is.gif
If each clock signal is 1 hz, and you have a billion of them, staggered
such that every 1ns part of the CPU can start, and finish, an
instruction - making the effective 'clock rate' 1 Ghz.
There is no real benefit to using a billion 1 hz clocks to make a clock
rate of 1Ghz and setting up such a system would be a large mess to CPU
designers. However, I find it fun to think about. Fun. Like a hobby, an
interest, etc.
In a "parallel Hz" device the bits maybe completely in serial and the
algorithms and tasks maybe totally non-parallelizable. However, the
frequency is still parallel.
The device I am proposing is completely serial except for the clock
rate.
My proposed device is completely serial except for the frequency. It
uses "parallel hz" but in terms of everything other than frequency, it
is totally serial and non-parallel. Only the clock rate is parallel.
Parallel hz = a method using N number of 1 hz clocks to gain a clock
rate of N hz.
My design has has a clock rate of 4 Ghz that is obtained by using 4
billion 1 hz
clocks. But otherwise, it is completely serial.
I recently crossposted my question to some other groups. One of the
responses was that my device would "leak" 3999999999/4000000000ths of
the time. What does "leaking" mean? What causes "leaking"?
Thanks,
Radium
interest, etc.
rate.
rate of N hz.
billion 1 hz
Thanks,
Radium
