Dori
Pieyed said:Buy radio clocks. They update to the atomic clocks in Boulder.
That is, if they can even receive the signal from the Atomic Clock in
Fort Collins.
Pieyed said:Your VCR and DVR do not rely on the AC line freq.
So, your entire post where you piss and moan about this "problem" is
moot, because there is NO problem, other than the one that resides
between your ears.
They BOTH use the same kind of clock a computer uses, which is from
your initial setting, and a 32.768 crystal oscillator.
IF the DVR uses a subscription service, THEY update your clock.
electronics, use the radio clock to periodically (you do know that word,
right?) update your shit electronics' clocks.
Sheesh, you still have a VCR in your SHIT gear stack?
The DVR most certainly uses a PC clock scenario, and the VCR may as
well.
So YOU do not know what got incorporated into either one either, you
COMPLETELY WRONG twit!
Well, the simple answer is, "By raising/lowering the speed of thebud-- said:It is easy to see how a single power plant can change the frequency for
an isolated system.
How does a "regional system operator" make fine adjustments in the
frequency of an interconnected grid?
Up to a certain point, the gyro mass of the rotor will cancel that.
For that type of motor, that is.
Many differences can be attributed to momentary outages as far as the
long term differential you described.
If it gets thrown off, it is NOT a successful "clock design" and
therefore does not even qualify as a clock at all. So none of you idiots
gets to call the failed designs "a clock" because NONE of them qualify.
You got that, you idiots?
Function is a prerequisite for use of the term. PROPER function.
Which is why you are completely clueless about it. You do not know
what the term function means, much less along with the modifier "proper".
The latter rings true in your case in particular.
Here are some more of his sock puppets for you to filter:
Fort Collins.
Why do you question my ability to be able to tell time? The clocks on my DVR
and VCRs run fast. How could or would you know otherwise?
And my Win XP computer automatically goes periodically to a time standard web
site (nist.gov) to correct any drift that might otherwise happen.
Not my
add-on, it's part of XP (as you probably know, since I see that you are a Forte
agent newsreader user).
By what supernatural powers do you claim to know the brands of my equipment?
You may not think much of Toshiba, Sony, but they are probably at least in the
mid-range of quality for consumer electronics.
Two of them. Enjoy the thought!
P.S. Don't bother responding as I've set up a filter to send your electrons
straight to the Junk folder - which is better than they deserve.
Wrong. DVRs have no Internet connection, DimBulb.
That's how the clocks run fast? What an idiot you are, AlwaysWrong.
A PC clock does not need the Internet, you retarded twit.
It is a 32,768 kHz crystal.
Show me where I said anything about an Internet connection, retard boy.
So, you are saying that phase differences always cause a positive shift
in such a clock?
The remarks mean that you are the idiot. Generally, such differences
are random, and in both directions, so the resultant change at the clock
would be negligible to nil. In your world, phase differences are always
such that an AC Line tied clock will always advance farther as opposed to
receding.
You should recede.
You're retarded.
You're a total retard, in fact. Announcing your filter file edit
sessions is the second most retarded thing a ditzy Usenet user like you
can do.
The top spot is for filtering to begin with. Your behavior is pathetic,
in fact.
This information is better than you deserve.
AlwaysWrong, crystals make *CRAPPY* clocks. You'll not get much
better than a few minutes a month from a raw PC clock, DimBulb.
The
AC line is *far* more accurate. What a dumbass, Dimbulb.
