Hi to all!
Thanks for being there!
Well, I need to design a small circuit and I have some doubts.
I have multiple inputs and I need to detect if I got a signal in more than one input at the same time. The signals are pulses of 30 mV and 55 ns of width.
I will use individual comparators for each input, and then add up all the outputs of the comparators and then use another comparator and check if it the result is more equal or more than two comparator outputs.
My question is related with the Vref for the input comparators. Since it will be around 20-25 mV I am not sure if my solution is the best option:
The idea would be to use a zener or a high stability voltage reference IC, and then a simple voltage divider with a trimmer in pararell the the R2 (grounded resistance) for fine tunning. Then I'll use a buffer to use this Vref with all the comparators.
Is this an appropiate method for setting a stable mV Vref? or there are better ways of doing it?
Thanks so much!
Any recommendations will be very welcome,
Thanks again.
Thanks so much!
Thanks again.
