Multisim9 is not simulating signal delay with inverters
Greetings,
I've created a simple circuit in Multisim9 (evaluation version),
(Windows XP)
with two ClockVoltage sources (digital oscillators). The first one goes
directly to an LED, the second one is fed through 6 hex inverters to
delay the circuit. There are 3 'tap' points after every two inverters
connected to a (virtual) oscilliscope.
With 'real simulation' settings, the 'tapped' points show no delay on
the oscilliscope. With 'ideal' settings chosen, the 'tapped' points
display just a flat waveform.
Here are pics :
http://putfile.com/pic.php?pic=main/...5569.jpg&s=f10
http://putfile.com/pic.php?pic=main/...2134.jpg&s=f10
Any idea why the delays are not simulated / displayed? I'm using
default settings for the simulator.
I also set up the same circuit in MicroCap.
With MicroCap's "Probe Transient" menu, I'm getting the expected
resuts.
http://putfile.com/pic.php?pic=main/...2012.jpg&s=f10
Mike
¦¦¦SHADOW¦¦¦
Do you mean they are not showing the propagational/setup time delays? I
still use MS7 and I don't remember it being in there. If I'm not mistaken,
the delays are only a few nanoseconds in real time, maybe you need to zoom
in more to see it? Setting the timebase very small should show the clock
edge as a steepening ramp.
