K
Klaus Kragelund
Hi
We are using an Icoupler to transfer TX serial data across a barrier with 115kBaud
I need to transfer a digital signal with low bandwidth across the same barrier
The following link is a initial idea:
www.electronicsdesign.dk/tmp/2Channels_ViaOpto_V0B.pdf
The idea is that the TX data runs through pretty much without being affected to the signal "TX"
On the primary side a circuit can inject a high frequency signal for a short time. On the secondary side the HF signal is caught by the advance of a ripple counter (4017). The clock rate is significantly higher than the TX rate and higher than the reset signal, so when the short time slice with manypulses occurs it will set O3 output high for long enough to charge the "OtherSig" capacitor.
On the surface it behaves well, but I perhaps someone has an better and simpler idea? (I have looked at a microcontroller to decode the signal, but that takes to much current)
I may even be that just a glitch detection circuit could do it, but the ones I have sketched up quickly has too many parts.
Regards
Klaus
Regards
Klaus
