multi direction dc motor
[dear i are you using microcontroller and a DC motor than there is no need of using four transistors. ti rotate the motor in two direction, you can use two transister and by inverting pins of microcontroller.
sherjan,
Only if you have dual supplies. A 4 transistor H-bridge does this with a single supply.
Bob
You're right about the BD681G greeniekin, it's a Darlington transistor. They have fantastic gain figures but suffer from very high saturation voltages.
As you also found the 2N2222 has a quite high Vsat too at its higher current ranges and is thus not suitable for this low-voltage application.
But so-called lo-sat transistors are plentiful, just Google for the term and you'll get half a million references to browse through, also from suppliers.
I remember being astonished by the extraordinary spec's of the Zetex transistor range some 20 years ago, but there are other good makes too.
Attached is a suggestion for a MOSFET bridge driver circuit. Again I have no specific transistor reference since there are so many to choose from.
It's not tried and tested but it should work. The NPN can be a logic-level N-channel instead. Also here take care not to take both inputs high at the same time.
Well I really didn't find any better parts, and in some ways I feel stupid.
I was using an arduino uno. Which has a 5v regulator inside it and I was trying to use that to power my h-bridge. I ended up directly hooking it up to the 9v battery that powered the arduino. I didn't think of this initially because i was plugging an adapter directly into it. I probably could have hooked the positive lead from my h-bridge int the Vin connection on the arduino and it would still work when the arduino is plugged into the wall adapter. I have not tried it though.
In the future I might just use a motor driver chip, but it was a great learning experience.
though Resqueline I will look into that as I would like to use some smaller and lighter batteries in the future.
If you searched only Jaycar I'm not surprised you didn't find any good transistors. Their selection leaves something to be desired.
I spent some time searching DigiKey and compiled this list of small (TO92) high-gain low-sat transistors. It's by no means complete.
2SB1592(0RA), PNP, -25V, -3A, 220mV @ 25mA & 1.4A, 130 @ 1.4A & 2V, 1W, 150MHz, TO-226-3, TO-92NL-A1 Long Body.
FPN530A, NPN, 30V, 3A, 250mV @ 100mA & 1A, 250 @ 100mA & 2V, 1W, 150MHz, TO-226-3, TO-92-3 Long Body.
FPN630A, PNP, -30V, -3A, 250mV @ 100mA & 1A, 250 @ 100mA & 2V, 1W, 100MHz, TO-226-3, TO-92-3 Long Body.
ZTX1051A, NPN, 40V, 4A, 210mV @ 100mA & 4A, 300 @ 1A & 2V, 1W, 155MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX869, NPN, 25V, 5A, 220mV @ 100mA & 5A, 300 @ 1A & 1V, 1.2W, 100MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX849, NPN, 30V, 5A, 220mV @ 200mA & 5A, 100 @ 1A & 1V, 1.2W, 100MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX1049A, NPN, 25V, 4A, 220mV @ 50mA & 4A, 300 @ 1A & 2V, 1W, 180MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX618, NPN, 20V, 3.5A, 255mV @ 50mA & 3.5A, 300 @ 200mA & 2V, 1W, 140MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX718, PNP, -20V, -2.5A, 260mV @ 200mA & 2.5A, 150 @ 2A & 2V, 1W, 180MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX1149A, PNP, -25V, -3A, 300mV @ 70mA & 3A, 250 @ 500mA & 2V, 1W, 135MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX948, PNP, -20V, -4.5A, 310mV @ 300mA & 5A, 100 @ 1A & 1V, 1.2W, 80MHz, TO-226-3 (TO-226AA), TO-92-3
ZTX949, PNP, -30V, -4.5A, 320mV @ 300mA & 5A, 100 @ 1A & 1V, 1.58W, 100MHz, TO-226-3 (TO-226AA), TO-92-3
STX690A, NPN, 30V, 3A, 400mV @ 100mA & 3A, 100 @ 500mA & 2V, 900mW, 100MHz, TO-226-3 (TO-226AA), TO-92-3
