MPPT charge control Project - LT3652
I am doing a Solar powered power bank as my dissertation project. It's based on LT3652 charge control, a Lithium-Ion battery (4500mAh) and 2 boost converters (3.3-5V and 3.3-12V).
I am using a 21W, PV panel with a maximum voltage of 7.68V. I need 4.2V and 2A output to charge the battery.
In calculations I did set minimum voltage in, as 6V and float voltage as 4.2 and followed the datasheet.
My design is based on Sparkfun Sunny Buddy MPPT. I changed the inductor (SDE0805A-100M) and diodes (RBR5LAM30ATFTR) and also sense resistor.
Unfortunately I'm not getting what I need out. Pictures speak better than words.
1.My schematic.
2.The actual prototype board
3.The open circuit voltage out. (7V in, 4.2V out)
4.Voltage out with 4.7ohm load.(6V in, 1.5V out . If i change the input voltage any higher and lower than 6V output voltage drops!)
5.Current out with 4.7ohm load.(6V in, 220mA out It goes up to 240mA at 7.6V in).
I appreciate your thoughts and advise as my deadline is reaching and i have been all over the place but i couldn't find the fault. as you can see I have changed the calculated 3.2uH inductor with a 10uH one but it didn't make much of a difference!
Ps. Sorry for the long post, I just wanted to give you as much as information as i can.
At first glance, it looks as though you feedback resistors R3 , 4 and 5 are incorrect. Have a look at the datasheet schematic and text.
I only followed the data sheet. here my calculations. please take a look and let me know where the error is.
The charger IC checks to see if the battery voltage is within limits to begin charging at full current. You don't have a battery so it's probably this that is causing the issue. The IC will only give you 15% of the programmed current if it senses a low battery voltage, which is about what you are seeing. This feature is common to most of the battery charging ICs I have seen, it's to protect a very discharged battery initially.
Adam
