I am trying to increase visibility of my motorcycle by adding red running lights that also function as a brake light to the rear turn signals on my bike. I have already picked out which lights I will use, Putco 1157 red LED's.
I have clear turn signal covers/lenses and I am going to modify the housings so that each rear housing fits one 1157 bulb and one 1156 bulb. (1157 has two positive terminals, 1156 only has one).
I will have 4 leads going to the rear turn signal housings, ground, turn signal, running light, and brake signal. I want to wire this LED so that it does not turn on when the turn signal is on.
When I turn the turn signal on, the running light lead turns off (I believe it floats when it is off, I am going to double check tonight by checking the voltage of the lead and then checking for connectivity between the lead and the ground). I am thinking I could use the running light lead to disable the brake light from turning on while the turn signal is engaged.
Originally I thought would be able to make a simple circuit with just one transistor, with the source connected to the brake power lead, the drain connected to the brake lead on the LED, and the gate lead connected to the running light. This way, when the running light is off, the transistor won't allow current to go into the brake lead to the LED. However, I wasn't sure if this would work because the gate and source would both be exactly the same voltage, and I'm also not sure if the transistor could possibly cause the brake lead to be activated by the running light lead.
Does anyone have any ideas on what type of circuit I should build to make this work the way I'm thinking?
