I'm trying to automate the motion of some props in a haunted house, and noticed that many halloween sites sell motors to achieve this. I don't want to buy any of the motor kits online since there is no funding for the project (school Fall Festival), and wanted to piece this together using mostly parts I have.
We already have a pulley assembly where a volunteer pulls a cord up-and-down to give motion to the props. Rigging it for a motor should be a snap. The motor I have is a 12V DC motor, 1/30 HP, 20 in-lb torque and 100 RPM speed. 100 RPM is waaaay too fast so I need to step down the speed. I've seen DC speed controllers online for 12V motors, but the highest amperage I've seen is 30A. The power curve on this motor shows a continuous 6A draw at 100 RPM, with the amperage increasing to 60A for very slow rotation. Does this mean I need a 12V/60A speed controller for this motor, and if so, any idea where I can find one (an inexpensive one, mind you!). Or would the 12V/30A be okay? I definitely don't want to start a fire here....!
Less important... I'm trying to find a 12V motion sensor to use to further automate this setup. The MAIN reason I'm doing this is because the motor states it is an "intermittent duty" motor. I know that a continuous duty motor is made to run 24/7 if needed, but how long can an intermittent duty motor run before it needs to "rest"? All of this is greek to me. If you think it would be okay to run for 4 hours straight, I won't need to integrate a motion sensor (although it would be a cool thing to add some fright to the setup!). Thanks so much!
