Arouse1973
Adam
I tell you what. This HOP bloke is good aint he?
Isolation transformers make some measurements possible, but not necessarily safe. And, yes, working with electricity can be dangerous. You have to know the consequences of "floating" a circuit if, by mischance, you make a connection that defeats the isolation.
Last year I purchased some Cree power MOSFETs and Cree Schottky diodes from Digi-Key, intending to use these to power a homemade PWM stepper-motor driver/controller that will be used to tune a pair of trombone capacitors on a magnetic loop antenna I am building for the 80m and 40m Amateur Radio bands.
There are integrated circuits available that allow "micro-stepping" stepper motors, thus allowing direct-drive to the antenna tuning capacitor, and that was (and is) my intent. However, the MOSFETs and the Schottky diodes are now packed away until I get a basement workbench cleared off after several decades of neglect. When that happens, I will have an electronics lab (and a ham radio shack) again and can continue pursuing this electronics hobby in retirement. Meanwhile, you are on your own selecting appropriate diodes. If the switching frequency is in the low kilohertz range, I would try 1N4007 diodes first before venturing to the much more expensive Schottky diodes. It is really expensive to get a high PIV (Peak Inverse Voltage) rating for a Schottky diode. I think I purchased the Cree C4D02120A silicon carbide Schottky diodes for my project.
Hop
I received my Novice Amateur Radio License (KN8UTJ) while serving in the Air Force from 1963 to 1967. IIRC the "ticket" was issued in the summer of 1966 and expired in the summer of 1967, soon after my enlistment was finished. I should have traveled to Columbus OH and taken the tests for either Technician (5 wpm code test) or General class (13 wpm code test) licenses, but didn't. Back in those days it was upgrade or out. The Novice "ticket" was not renewable.Hi Hop,
I kinda imagined you must have been an amateur enthusiast back in the 60s-70s (it just fits you totally ),
as so many electronics lovers were at those days.
I would think with the Web of today that would be a "redundant hobby" ,but looks like it is still alive and kicking.
Never heard of trombone capacitors tuning till now,
the closest I new about was cavity tuning
(for much higher frequencies than 14Mhz).
In the old days they were called antenna-tuners,
some were fully hand cranked others were automatic-motor driven.
Are you into Morse as well?
What kind of Transmitter are you using,
I guess it is an "all Analog" old one...
