I'm trying to implement (in spice) some small circuits I've seen in
lectures. I'm hoping that someone can confirm my thinking, with regards
to biasing and feedback.
I've got a basic nmos inverter with pmos load, and I'm generating the
bias for the pmos transistor by mirroring it off a reference, as shown
here:
http://www.flickr.com/photos/tedthornton/313065110/
The W/L ratios of the transistors are: M1,M2=(129/5) and M3=11/1.
At the moment, I'm only interested in biasing the circuit up, so I just
stuck a 1V DC source onto the input of M3. However, the circuit didn't
quite work - the drain current through M2/M3 was only about 85uA and M2
had dropped out of saturation - the voltage at node 4 was 2.93V (so for
M2, Vds=-0.37V, but Vgs-Vt was -0.404V).
After a bit of reading and thinking, I suspected that the voltage at
node 4 was not well defined, so I used a VCVS with gain 1 to feedback
the output node voltage to the input (node 5). This sorted out my
problem - I got 100uA down Id2/id3 and all transistors stayed in
saturation.
So is this the right thing to do? In lectures we considered only the
two transistors M2 and M3 and ignored biasing conditions (ie. just
looked at the AC performance of the circuit). They didn't mention
feedback... is it required?
Cheers,
Ted
here:
saturation.
Cheers,
Ted
