MOSFET capacitor
Hello,
I am designing an IC amplifier and i want to remove the DC component
from the output.
I thought of using a capacitor.
How can i implement a capacitor using a MOSFET. I heard i can connect
the drain to source but how do i control the equivalent capacitance?
Pooh Bear
Hello,
from the output.
Maybe you could elaborate on the exact meaning of " I am designing an IC
amplifier " first before going any further ?
Graham
Jim Thompson
Hello,
from the output.
MOSFET capacitance is simply the gate capacitance.
HOWEVER: There is a series resistance component which varies with
bias, and it is NOT modeled by the MOSFET Spice model alone.
...Jim Thompson
josh lawton
I think you need to spend some more time learning the process. You may
have a capcitor option wich gives less voltage dependence by using a
high implant, or possibly poly-poly capacitor.
Be careful when using a normal pmos or nmos as a capcitor. If you are
below the threshold volatge the capacitance is very low. Using a
depletion device can solve this.
