Jag Man
(See thread " Special "dual" pulse generator circuit " and "Porblems with
NTE3083(4N32)" for recent discussion on this
project)
I have now modfied my circuit to trigger the pulse width setting 555s on the
leading edge of
the pulse from the decade counter. See the schematic at:
http://sowell.ecs.fullerton.edu/jag/fuelingsys/tester120404.jpg
The current problem is that at SOME frequencies, as set by the triggering
555 (leftmost
in the diagram), the pulse width of the outputs cannot be set any wider than
the width of the pulse out of the 4017 decade counter. That is, the circuit
is supposed to
allow me to set the output pulse width from something less than 1 ms to 10
or 11 ms
for triggering rates between 45 and 260 Hz coming out of the decade counter.
Sometimes
it works, but at certain freqencies the pulse width is limited to the pulse
width th the
decade counter output pins. For example, if I set the frequency low, e.g.,
50Hz, and then set the
pulse width of the channel 1 output (upper signal flow path in the diagram)
to some
high value, e.g., 10 ms, then slowly increase the frequency the output pulse
width will
decrerease, dropping off to 3.8 ms at 260 Hz. Channel 2 appears to be OK at
low and
high frequencies, but at certain intermediate frequencies the pulse width
does change with
frequency. None of this should happen; the pukse width should be rock solid
as frequency is changed.
I find this very strange, and cannot see why this is happening. I have
looked at the
signals at points all along both paths and things look pretty much as I
would expect.
For example, the the output pulses at the decade counter are correct for
the set frequency, and the triggering pulse at pin 2 of both pulse width
setting
555s is about 0.2 to 0.3 ms. The problem appears at pin 3 of the pulse
width setting 555s. It appears that this voltage is sometimes getting pulled
back to 0
at the end of the decade counter pulse, rather than the time determined by
the
555 RC product.
Any suggestions?
TIA
Ed
project)
leading edge of
555 (leftmost
is supposed to
or 11 ms
Sometimes
width th the
to some
width will
low and
does change with
looked at the
would expect.
setting
back to 0
the
555 RC product.
Any suggestions?
TIA
Ed
