Steve Watson
Is it possible to produce a circuit that operates at a _lower_
potential than actual ground so that electrons flow from ground into
it ... instead of the convention whereby electrons flow from a higher
potential into ground?
By "actual ground" I mean a rod physically in the ground, not a
relative ground created by dividing a positive voltage, as in a dual
rail supply.
For example, if an AC driven transformer (with a split secondary) is
wired with its center output tap to ground, does one side of the
winding draw electrons into ground and the other side draw them away?
Steve Watson
rail supply.
Steve Watson
