More fun with a Yamaha EF1000is
V
Vaughn Simon
We took delivery of our second Yamaha EF1000is where I work. Our plan is to run
one tank of fuel through each and then put them on the shelf to (hopefully)
never be used again, so I decided to evaluate this second one on my own time and
try to produce some useful information for the group. First of all the basic
results:
1) First I connected it to my 2-door 22 cubic foot refrigerator to see if the
little Yamaha could even start it...it did. Once running the 'fridge, I added
the circuit to my study and started turning things on. When I was done, the
little guy was revving at max while running my desktop computer with all of its
accessories, my 13" CRT color TV, a CF Lamp, and the ceiling fan. I have a
(very approximate) watt meter on my transfer panel, and it was reading about
6-700 watts with all that stuff connected. A moment later, the defrost cycle
started on my refrigerator, and I was suddenly reading something over 1000
watts. I quickly removed the study circuit, and the load settled down to a
steady 600 watts (the defrost heaters in the refrigerator)
2) After that brief first test, I carefully refilled the tank (.66 Gal) to the
mark and restarted to discover how long it would run my refrigerator on one
tank. Results: 11 Hours.
Earlier, the other Yamaha barely even seemed to notice our 15 cubic foot shop
refrigerator and ran for about 14 hours. I was very interested to see how it
would do on this larger unit. There are two issues we need to be concerned
about when considering running these large boxes with such a minimal generator;
1) starting surge and 2) defrost load. "Frost Free" refrigerators have
substantial heaters that run periodically in place of the compressor, to defrost
the evaporator. Unfortunately, these heaters draw more than the compressor, but
fortunately they have very little startup surge compared to a motor.
CONCLUSIONS: If you are looking for low-noise operation that wrings the absolute
most hours of operation from a gallon of operation, and are willing to settle
for just running your refrigerator and perhaps a few other low-drain items, the
Yamaha EF1000is will PROBABLY do the job for you. The reason I say probably is
that you can't know until you try it with your own refrigerator. If your box
has too much starting surge, you can try a "hard start kit" which connects to
the innards of your refrigerator with only two wires and should significantly
reduce your unit's starting surge . (For hard start kits try here;
http://www.supco.com/eclass.htm and then Google for more knowledge) Caution:
This is the Internet and I am talking about something I have never tried myself.
@ $3.00/gallon the EF1000is will run my refrigerator for (.66 X 3.00 / 9 ) 22
cents per hour. If you were reasonable frugal, this unit and 10 gallons of gas
could keep you going for a full week with refrigeration, and small loads such as
a fan, a few CF lights, a small TV and your cellphone charger.
For comparison, my little Honda EM600 will barely run for 8 hours on .5 gallon
of gas (light load) and will never (even on its best day) start my refrigerator.
The Yamaha comes with a 2-year warranty for home use (1 year for commercial).
The pollution tag indicates that it is intended for "extended" operation, the
highest of three ratings.
Regards
Vaughn
W
wmbjk
results:
Great report, very practical information. Thanks for taking the time
to write it up.
Wayne
V
Vaughn Simon
...........Rob said:
Just one qustion Vaughn, would it start the fridge while the
ecco throttle was on?
Yes. The overload light woud flicker, and the generator would rev briefly,
but my refrigerator always started up without drama. I operated the unit in the
eco mode the entire time.
I noted that my 600 watt Honda will not begin to start this same
refrigerator, I should also mention that it will not start reliably with my
1000-watt square wave inverter. I think the sine wave makes all the difference.
Vaughn
W
William P.N. Smith
Thanks for the write-up, Vaughn! Do you think you'll have any trouble
starting it after allowing the gas to dry out in the fuel system?
V
Vaughn Simon
Nope. That is exactly the way the manual says to store it, and that is the
way it comes shipped from the factory. Just like on the Hondas, it even has a
little valve on the bottom of the float bowl so you can drain the last little
bit of gas out. For example, the EU2000i manual specifically tells you drain
the fuel tank and carb for storage over 6 months.
If there is no gas in the carburetor, there is nothing to turn into goo and jam
up the works.
Vaughn
W
William P.N. Smith
Oh, excellent! Sounds like a good product, thanks again for the
feedback on it.
V
Vaughn Simon
Ulysses said:
Thanks for the review. It sounds like it would take approximately 1 gallon
per day to run my 18 cu/ft fridge.
How often does Yamaha say to change the oil? Do they recommend regular
10W30?
Yes, regular 10W30 (depending on temperature extremes). These things take
so little oil, that you may as well buy the best while you are at it. The books
are at the shop, so I will post on the oil change intervals tomorrow.
Vaughn
Bruce in Alaska
take
books
Vaughn
I would expect that it would be every 50 hours if it is NOT a Pressure
Lube System, without an Oil Filter. If it is a Pressure Lube System with
an Oil Filter, you would expect somewhere between 100 and 200 hours.
Bruce in alaska
