Pimpom
My 7-year old CRT monitor has developed an intermittent fault.
Sometimes the screen goes black but the power LED remains green
(doesn't turn amber). A sharp rap often restores the display.
When it decides to act up, the LED stays green even when it's
turned on for several minutes while disconnected from the
computer.
I did a lot of repair work on a wide range of electronic products
up to the early nineties, but I'm quite rusty now. I've opened up
the monitor but can't see anything obvious in the way of a dry
solder or loose connector. The tube heater glows all the time.
The signal cable goes first to the tube base PCB and connections
to the main PCB are with two flat cables.
Which signal line does a computer monitor use to detect the
presence of a signal? Where do you think I should start looking?
Thanks in advance for any input.
computer.
