Monitor Compaq V500 (chassis Samsung CHB5705); black has red hue.
I've been given a monitor. It works pretty fine, but for one thing:
There's a red teint across the screen, especially in the black areas.
When I turn contrast fully down, the screen doesn't become black but
red. With contrast fully turned up, it's perfectly normal picture,
except in big black areas, where it shows a red hue again.
When I turn brightness down, it also becomes more red-dish, but not so
extreme as with the contrast fully turned down.
No retrace-lines, or other problems.
Could it be a heater-cathode short? Or something else? I suspect the
red channel, of course. However, I'm reluctant to operate this monitor
without being pretty certain where to start looking. At the moment,
it's the only monitor I have...
Also: I use this monitor in 1024x768 mode, but when starting up, it
goes to 640x480 (I think). In that resolution, it shows severe ><
distortion. (barrel distortion?). For my standard resolution, 1024x768,
I can perfectly correct this, but in other modes it shows up again,
severely. Is this expected behaviour of this monitor?
Model: Compaq V500
Chassis: Samsung CHB5707
A schematic I've downloaded from here:
http://www.eserviceinfo.com/downloadsm/7677/Samsung_CHB5707.html
(click on download).
Hope anyone can help.
Peter.
Jerry G.
This is common in these when the CRT starts to go weak. The bias
circuits can no longer properly bias the CRT.
If you call Samsung, maybe they will sell a copy of the service
manual, to you. Normaly, they only supply their authorised dealers.
With the schematic, you should be able to check the bias drive
circuits. But, failure in these is rare.
Jerry G.
I
ian field
Model: Compaq V500
Peter.
Presuming this is a CRT display - monitors invariably have the heater supply
derived from the main chopper transformer with the usual rectifier/reservoir
cap, the cap can go high ESR so the power to the heater is reduced which
under-runs the cathodes and causes a rapid deterioration in emission!!!!!
Also some years ago some 'genius' at Philips issued a memo to the trade that
due to the better regulation of modern PSUs, CRT heaters should be run at
6.15V instead of 6.3V and quite a few monitor manufacturers actually fell
for it!!!
If you find the heater voltage is too low (I've seen as low as 5.75V!) there
is sometimes an alternative to risking safety by cranking up the B+ preset
in the hope of increasing the Vhh. Check if the heater rectifier is a fast
soft recovery type or Schottky-barrier, if it is not an SB type then
replacing it with one will increase efficiency and increase the rectified
heater voltage. However since the chopper PSU is usually a flyback type
converter you have to start by making a peak detector with opposite polarity
to the heater voltage to measure the peak reverse voltage the SB diode will
be subjected to! Use a diode similar to the existing heater rectifier - but
pointing the other way round, and give it it's own reservoir electrolytic
(voltage rating 5x that of the heater reservoir cap!) the SB diode must
withstand the sum of the reverse voltage and the 6.3V on the reservoir cap!
Try to get hold of a 60V 3A SB diode, this may be sufficient but if not
leave the peak detector diode/cap combination and load it with a power
resistor - trial & error to determine what value loads the reverse voltage
low enough. Note that SB diodes have higher junction capacitance so it helps
reduce heating in the reservoir cap if you pad it with a decent size
polyester cap - say 1 or 2.2uF.
Another thing I find causes loss of emission is long periods of low beam
current (like many screen savers!) scan a blank sheet of white paper and
save the file as (BMP I think) to the wallpaper folder then use this as the
background, turn up the Bri & Cont controls and leave it running awhile,
this often wakes up sleepy cathodes.
Thanks for the replies!
I'll check for bias and heater voltage. Thought that 6.15 V is still
within the margin (6.0-6.6V) for heaters, but still. At least the lower
heater voltage should assure long life of the filament :)
To be honest, the monitor isn't really worth all the trouble. It's just
that I'd like to know what is going on.
I'm assuming the barrel-shaped distortion is completely unrelated to
this red-hue problem, right?
Peter.
I
ian field
Peter.
Short of hitting it with a hammer under-running the heater is the quickest
way to ruin a thermionic device!!!
The life graph was posted on a guitar amp forum at a time when some
guitarists started discussing reducing the voltage supply to a tube amp as a
means of producing a specific type of distortion. The graph as posted shows
a steady downward slope for cathode life against excessive heater voltage,
and a nearly vertical drop for underrun heaters! In all my years servicing
CRT based displays, I've seen maybe less than a dozen O/C CRT heaters - it
just doesn't happen that often, if the heaters are overrun it will boil off
the emissive coating long before heater life becomes an issue!
Ancient_Hacker
red.
There are three little trimpots labeled R G and B Screen. Most of the
time you find them on the little PC board on the end of the CRT, but
sometimes they're on the bigger PC board. Take great care and try
turning the "Red screen" control a smidgen counterclockwise. There's a
good chance this will fix the problem. Don't kill yourself.
