My mother-in-law has a mobility scooter with 24VDC power modules that each contain 2 12V AGM lead acid batteries and a charger mounted internally that connects to utility power via a common power cord such as those used for personal computers with IEC 386 receptacles. This charging component is rated at 100-120VAC 50/60Hz 1.2A input, and 24VDC/1.5A output.
One of the units fails to charge now. Initially, the charge light showed green instead of red, and now it does not illuminate. I disassembled it and discovered that the scooter maker seems to have taken a charger that is commonly available in a similar form (it is identified as a High Power HP1201-2) and hacked it so that:
Please refer to the diagram in the inset of the photo attached to this post. The power supply DC output connects to the remainder of circuitry of the power module shown in the diagram via the connector depicted in the yellow shading. When the entire power module is mounted on the scooter, it connects via the four-prong receptacle depicted in the green shading. The final bit of shading, in pink, depicts an axial lead diode. That diode is shown in the photo. It was encased in shrink tubing that had fused to the surface so I had to scrape and peel to expose it with limited success. I would like to identify it and determine if it is faulty and replace it if appropriate.
I know very little about electronics, but I tried some tests with a multimeter. I hope this provides enough information for someone more experienced to render advice:
Finally, how do I identify the diode in its degraded condition? Failing that, what would be an appropriate diode for this circuit? And stretching your indulgence - where is a good place to get them?
Thanks for your attention.
- The integral red/green charging/charged indicator LED is disconnected, and three additional wires were drawn out through the DC output end to drive a LED for the same function, but mounted through a hole in the larger case where it can be seen.
- The three prong external plug for DC output that the original unit was designed to use was replaced by a plastic connector for use inside the scooter power module. Only two conductors are used.
- I tested the DC output voltage of the power supply with no load. It indicates 65V ! Is this because there is no load, or is it malfunctioning?
- I also speculated that the diode might be failed in an open circuit state, So I tested it with the diode test function of my meter. It indicates open regardless of which lead I apply to which end.
