Pride Jazzy 614 HD. Error code shows electromagnetic brake issue. Both brakes and motors tested with direct 24 vDC and work fine.
Is there any way to bypass or trick the controller into thinking the brake is working? This is not a safety issue as the scooter will not be used for carrying a person. Don't know if the issue is in any wiring or actually an issue with the expensive controller. I suspect the controller is sensing a brake error and thereby not allowing current to the electrometic brake and motor.
