MIxer requirement
hi friends, if i use mixer to translate 110 to 170 Ghz into 0.1 to 18 GHz then which type of mixer will be usefull and which company will provide it. plz mention the model no of mixer also.:)
davenn
hey there,
this is obviously in relation to your previous topic. my knowledge of such stuff ends around 50GHz. what you are after is very specialised and probably extremely expensive.
you would need to start contacting some of the big microwave equip supply companies
do some google searching and see how you get on try searching for "harmonic mixers"
for the freq range you are interested in
all I can say is good luck :)
cheers
Dave
I know where you are coming from. I use "Virtual DJ" on my laptop and spinn at alot of parties. all I do is use a cable that will plug into the headphone jack in my laptop and plug it into eather the amp or whatever you want your sound to come from. You want alot of ram (like at lease 500+) and the sound card bit.... you will have to shop around for one that will work right for you. I just use the one that came in the laptop. you can check out my mixes at (url removed) I did all of them using my program. if this really didn't help you or you have another question email me at (E-Mail Removed) and I will be able to help you out.
davenn
totally irrelevant and wrong end of the spectrum and not RF :eek:
Dave
