Mitsubishi WS-55805 rearscreen projection repair advice
I
Isaac
I was recently given a Mitsubishi ws-55805 rear screen projection TV for
free. The TV was definitely showing a vertical reflection problem. If the
TV is off for several hours, the screen is perfect. But as time goes by the
top of the screen starts to shrink down; just a few inches in 30 minutes.
Add more time and eventually the screen will shrink to a line in the middle
of the screen while the bottom half is perfect. When I was given the TV the
previous owner decided not to repair on the advice of the repair shop,
stating the repair was going to be too much and with just a little more,
they could get a new TV. Since they bought a new tv, I was able to acquire
it for free as long as I moved myself. That was fun :)
I had a local electronics shop come and give me an estimate to repair. They
could not give an estimate on site, so they pulled the guts out and took
them to their shop. The next day they gave me an estimate of $465.00US to
repair the TV. They said that there were issues with the vertical
deflection and power systems.
I don't know what parts are needing to be replaced, Is this TV worth
putting this much money in to a repair? I cannot buy this TV for this much,
but on the other hand if components are already failing, could there be
more failures to come? I thought about buying the schematics and trying to
fix it myself, but with the cost of the tools I would most likely need, I
would be close to the repair cost. And, I do have doubts I would be able to
troubleshoot it properly ending up with a solid repair. I have done basic
repairs such as cracked solder joints, replacing leaky caps, and bad chips.
But there are no apparent problema with the TV by sight.
Does anyone have any advice for someone in my situation? Should I ask more
questions about the repair? If you need anymore information, I will try to
provide it. But the shop is being vague, I guess they don't want to do the
diagnoses and then have someone else do the repair.
Isaac
Leonard Caillouet
I'd be surprised if there were PS problems. Sounds like a pretty typical
case of bad solder joints on the vertical output IC, a bad output IC, or bad
caps related to it. I would never give an estimate as vague as "issues."
You should get more specific information about what they propose needs to be
done.
Where are you located and does this estimate include trips to and from the
home to pull and re-install the light box and alignment?
Leonard
I
Isaac
I am located in the Atlanta area. Since they picked it up; I assume they
will bring it back and install it with all of the proper techniques. But to
be sure I will be adding that to my list of question I will be asking
tomorrow. They told me it would be a free estimate if I brought it in, or
$25.00 to come to the house, which seemed like a good deal since I really
didn't want to be hauling the TV around town. They never charged the
$25.00, I assume becuase they needed to take the parts to their shop. I
wasn't there when they came to do the estimate. Thank you for your input,
it is much appreciated.
Isaac
Scott Lane
the
middle
the
They
much,
to
chips.
Isaac
I went to a customer house to look at his Mits VS-50609 . The red
convergence was way out, but only on the top half of the screen. The red
dropped way down from the top of the picture. Went to the convergence menu
and it had a setting "Restore Factory Default Settings". Reset it and the
alignment popped back in the top half and was perfect after that. I checked
his convergence IC was STK393-110. The screen has a burn mark in it now from
running out of alignment but it doesn't look that bad.
I would ask the shop for a time estimate on your repair. If it is over two
or three days I would want to know why so long. If you feel they are blowing
smoke then ask for your gear back. I have a Magnavox to work on, 60 inch
that the customer paid over $500 to a shop and after he got it back it
wouldn't even turn on. Had to go back to the shop again. Then he got it back
and a couple months later it started just shutting down after about 10
minutes. I verified it, shuts down. I don't even want to work on it. It is a
"worked on dog". Those are usually the hardest or impossible to repair. I
know a lot of people won't even try to fix something if it has been
"hacked." Good luck. Scott
