Mitsubishi VCR Belt Quality query
Salvatore
My HS-U650 once ejected the cassette with the door closed. This would
continue after I released it so I took the door off until I could find out
what gears got out of time. Worked fine for months and then began not
accepting a tape unless tried a number of times.
I ceased using it until I could get to looking at it. Now a year later, I
have it opened up and it will not even move the cassette.
Belt is intact but VERY malleable. If I pull it, it will stretch to twice
it's diameter and remain that way, then slowly shrink to it's normal slack
state. This seems to be my problem unless that is the way drive belts are
supposed to be, and that is my question. Should it be so soft and tacky
to the touch or is this the way they degrade??
Mark D. Zacharias
That belt is bad and needs to be replaced. Maybe you can get a shop to sell
you one. If you're in the US, Mitsubishi might stock it. 800-553-7278 (I
think)
Mark Z.
Asimov
"Salvatore" bravely wrote to "All" (22 Nov 04 02:06:19)
--- on the heady topic of "Mitsubishi VCR Belt Quality query"
Sa> From: Salvatore <[email protected]>
Sa> My HS-U650 once ejected the cassette with the door closed. This would
Sa> continue after I released it so I took the door off until I could find
Sa> out what gears got out of time. Worked fine for months and then began
Sa> not accepting a tape unless tried a number of times.
Sa> I ceased using it until I could get to looking at it. Now a year
Sa> later, I have it opened up and it will not even move the cassette.
Sa> Belt is intact but VERY malleable. If I pull it, it will stretch to
Sa> twice it's diameter and remain that way, then slowly shrink to it's
Sa> normal slack state. This seems to be my problem unless that is the way
Sa> drive belts are supposed to be, and that is my question. Should it be
Sa> so soft and tacky to the touch or is this the way they degrade??
Sa> Thanks
Elasticity is low and the viscosity is too great. They often use that
formula for the pitch on roofing tiles. Definitely change the belt!
How could you even imagine it is normal behaviour? Pffft! ;-)
.... Now touch these wires to your tongue!
Salvatore
Thanks Mark
Always saw them get brittle and break. I guess this "newer stuff" has
different qualities. I found a kit of the 2 belts for the deck for $2 +.
0
987
Steve Vassiliadis
3
1K
Gail Storm
1
2K
JVC dude
