Mitsubishi CK3536R Yoke Needed
  • Thread starter Shoreline Electronics
Make : Mitsubishi
Model : CK3536R
Part # 330P18101
The original one has a severe buzz (60hz). Would like to have replacement
as opposed to going the shellac/reglueing route. Customer is using the set
in the mean time. Would like to do this fix in one visit.
Anyone got one from a junked set?
Maybe other 35" yokes from this era are similar?
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
(860)399-1861
(860)664-3535 FAX
jstielau@snet.net
Leonard Caillouet
Jeff,
you might want to pull the yoke and shellac it. These are the ones that
short out. You can sometimes see a green spot on the windings where
corrosion is taking place. I think some of it is due to the dried glue like
you see on the boards. I have had several shorted yokes on these that kept
taking out vertical outputs. The only scrappers I have had on this model
have been for the bad yokes. Otherwise we fix them, caps and all and the
CRTs look surprisingly good for their age.
Leonard
