Mitsu VS-60vx3
Eddie Allen
Hey everyone,
Just found this forums and there seems to be some knowlegable people here so
I just wanted a little bit of direction if I may.
I recieved the tv from someone that told me it had a power supply problem.
Well they never had it looked at so I took it just to try.
The model is a Vs-60vx3 (60") (was made in 93 hence the reason parts may not
be availible I assume). I turn it on and it usually will turn right back
off.
When I can get the screen to come on at (very short time), all I can see
are the menu items(vol adj, channel, input etc). I plugged a dvd into the an
input and it show it very dark to where you can barely see it and blurry. If
I use the input buttom and go like input1(dvd) to input2 and back to input1
the screen will flash for a split sec to where I can see the dvd player but
then it goes back into the dark state. There are also shadows on all the
menu items as well. Thanks everyone if you have any advice if you can help.
I dont really want to take it too a tech until I am sure if it will be worth
it as this tv is pretty old. Just looking for a point in the right
direction. I am pretty handy with electronics but I have never tried to
repair a tv before so if it gets too involved I will end up taking it or
trashing it I guess.
I have also taken a look the boards and there does not seem to be any
burns...etc that I can see but I have not taken anything completely out yet.
Thank you very much for any info.
Eddie A
Skype_man
Mitsubishi T.V.'s of that era are KNOWN for lots, & lots
of bad capacitors, & bad PIP boards...caps also. Could be
20 - 30 bad caps, some will leak black juice on the board.
Sky.
Eddie Allen
Hi Sky,
Well I dont't believe this tv has a PIP, as I dont see an option on the
remote or any button on the front panel.
As far as the caps are they just randomly bad as in some on each of the
board or like mostly on the power supply board? Like I said I havent taken
any of them out of the base as of yet.
Eddie
Leonard Caillouet
Google Mitsubishi and capacitors, along with maybe the chassis number, which
is V12 or V12B and you will find lots of discussion about what you need to
do. Be prepared to change several dozen caps on all five major boards and
do some rework on the traces and solder.
Leonard
7
1K
Leonard Caillouet
4
1K
James Sweet
2
889
Leonard Caillouet
