Here's an interesting schematic:
http://www.redcircuits.com/Page123.htm
I was wondering what R7 would be connected to. (It's not clear in the
picture.)
What do you guys think of the schematic, overall? A good project for
a beginner?
Michael
I finally got a reasonably decent amplifier design with LTSpice. It is
essentially a high power op-amp. It can drive 37 watts into a 4 ohm load
with 48 watts input at the start of clipping with a 40 volt supply, and it
will work from 20 Hz to 20 kHz fairly well (according to the simulator). It
only draws about 300 mW (15 mA) with no input.
There may be better circuits, but this one is simple and tolerant of power
supply variations. It works at least from 24 to 48 VDC, and to within 3
volts of the supply rails. There is some crossover distortion but it
doesn't look too bad. It's probably fine for a guitar amplifier. I might
actually build this and see how it works for real.
Feel free to modify the design and see if it can be improved. It should be
a good project for a beginner, and is especially good in that it can be
simulated with LTSpice.
Good luck,
Paul
Version 4
SHEET 1 1304 744
WIRE 656 -272 -256 -272
WIRE -416 -208 -672 -208
WIRE -64 -208 -416 -208
WIRE 128 -208 -64 -208
WIRE 480 -208 128 -208
WIRE 128 -160 128 -208
WIRE -64 -144 -64 -208
WIRE 480 -112 480 -208
WIRE -416 -64 -416 -208
WIRE 128 -32 128 -80
WIRE 256 -32 128 -32
WIRE 352 -32 256 -32
WIRE 432 -32 352 -32
WIRE -256 -16 -256 -272
WIRE -256 -16 -320 -16
WIRE -256 16 -256 -16
WIRE -320 32 -320 -16
WIRE 480 64 480 -16
WIRE 656 64 656 -272
WIRE 656 64 480 64
WIRE -672 128 -672 -208
WIRE -64 128 -64 -64
WIRE -64 128 -176 128
WIRE 256 128 256 -32
WIRE 480 144 480 64
WIRE 528 144 480 144
WIRE 624 144 592 144
WIRE 656 144 624 144
WIRE -320 160 -320 96
WIRE -288 160 -320 160
WIRE -256 160 -256 96
WIRE -256 160 -288 160
WIRE -64 176 -64 128
WIRE -16 176 -64 176
WIRE 656 224 656 144
WIRE -112 240 -224 240
WIRE -16 256 -16 176
WIRE 128 288 128 -32
WIRE 256 288 256 192
WIRE 352 288 256 288
WIRE 480 320 480 144
WIRE 480 320 352 320
WIRE -176 336 -176 128
WIRE 256 336 256 288
WIRE 304 336 256 336
WIRE -528 352 -576 352
WIRE -416 352 -416 16
WIRE -416 352 -448 352
WIRE -384 352 -416 352
WIRE -224 352 -224 304
WIRE -224 352 -384 352
WIRE -208 352 -224 352
WIRE 480 352 480 320
WIRE -112 368 -112 240
WIRE -112 368 -144 368
WIRE 32 368 -112 368
WIRE 80 368 32 368
WIRE -288 384 -288 160
WIRE -208 384 -288 384
WIRE 256 400 256 336
WIRE -576 416 -576 352
WIRE -384 416 -384 352
WIRE 32 416 32 368
WIRE 128 416 128 384
WIRE -288 432 -288 384
WIRE 352 432 352 416
WIRE 432 432 352 432
WIRE -64 448 -64 176
WIRE 352 464 352 432
WIRE -672 560 -672 208
WIRE -576 560 -576 496
WIRE -576 560 -672 560
WIRE -384 560 -384 496
WIRE -384 560 -576 560
WIRE -288 560 -288 512
WIRE -288 560 -384 560
WIRE -176 560 -176 400
WIRE -176 560 -288 560
WIRE -64 560 -64 512
WIRE -64 560 -176 560
WIRE -16 560 -16 320
WIRE -16 560 -64 560
WIRE 32 560 32 496
WIRE 32 560 -16 560
WIRE 128 560 128 496
WIRE 128 560 32 560
WIRE 176 560 128 560
WIRE 256 560 256 480
WIRE 256 560 176 560
WIRE 352 560 352 544
WIRE 352 560 256 560
WIRE 480 560 480 448
WIRE 480 560 352 560
WIRE 656 560 656 304
WIRE 656 560 480 560
WIRE 176 608 176 560
FLAG 176 608 0
FLAG -576 352 Vin
FLAG 624 144 Vout
SYMBOL voltage -672 112 R0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V2
SYMATTR Value 40
SYMBOL voltage -576 400 R0
WINDOW 3 -75 232 Left 0
WINDOW 123 24 44 Left 0
SYMATTR Value SINE(0 350m 2000 1u 0 0 5000)
SYMATTR Value2 AC 1
SYMATTR InstName V1
SYMBOL nmos 432 -112 R0
SYMATTR InstName M1
SYMATTR Value STD30NF06L
SYMBOL nmos 432 352 R0
SYMATTR InstName M2
SYMBOL pmos 304 416 M180
SYMATTR InstName M3
SYMATTR Value IRF7205
SYMBOL res 336 448 R0
SYMATTR InstName R2
SYMATTR Value 1k
SYMBOL res 640 208 R0
SYMATTR InstName R8
SYMATTR Value 4
SYMBOL polcap 528 160 R270
WINDOW 0 32 32 VTop 0
WINDOW 3 0 32 VBottom 0
SYMATTR InstName C3
SYMATTR Value 4700µ
SYMATTR Description Capacitor
SYMATTR Type cap
SYMATTR SpiceLine V=35 Irms=2.03 Rser=0.033 MTBF=2000 Lser=0 mfg="Nichicon"
pn="UPR1V472MRH" type="Al electrolytic" ppPkg=1
SYMBOL res 112 -176 R0
SYMATTR InstName R4
SYMATTR Value 2.2k
SYMBOL res 240 384 R0
SYMATTR InstName R1
SYMATTR Value 220k
SYMBOL diode 336 -32 R0
WINDOW 0 -34 32 Left 0
WINDOW 3 42 35 Left 0
SYMATTR InstName D1
SYMATTR Value 1N4148
SYMBOL diode 336 96 R0
WINDOW 0 -38 -28 Left 0
WINDOW 3 40 35 Left 0
SYMATTR InstName D2
SYMBOL diode 336 224 R0
WINDOW 0 -33 28 Left 0
WINDOW 3 39 -30 Left 0
SYMATTR InstName D5
SYMBOL res 112 400 R0
SYMATTR InstName R3
SYMATTR Value 100
SYMBOL res 16 400 R0
SYMATTR InstName R6
SYMATTR Value 100k
SYMBOL Opamps\\LT1037A -176 304 R0
WINDOW 3 9 107 Left 0
SYMATTR InstName U1
SYMBOL res -432 336 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName R12
SYMATTR Value 10k
SYMBOL zener -48 512 R180
WINDOW 0 24 72 Left 0
WINDOW 3 24 0 Left 0
SYMATTR InstName D6
SYMATTR Value BZX84C15L
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL res -80 -160 R0
SYMATTR InstName R5
SYMATTR Value 4.7k
SYMBOL polcap -32 256 R0
SYMATTR InstName C4
SYMATTR Value 100µ
SYMATTR Type cap
SYMATTR SpiceLine V=63 Irms=900m Rser=0.1 MTBF=20000 Lser=0 mfg="Nichicon"
pn="UPH1J101MRH" type="Al electrolytic" ppPkg=1
SYMBOL res -272 0 R0
SYMATTR InstName R7
SYMATTR Value 100k
SYMBOL res -304 416 R0
SYMATTR InstName R9
SYMATTR Value 1k
SYMBOL res -400 400 R0
SYMATTR InstName R11
SYMATTR Value 10k
SYMBOL res -432 -80 R0
SYMATTR InstName R10
SYMATTR Value 1meg
SYMBOL nmos 80 288 R0
WINDOW 3 49 86 Left 0
SYMATTR InstName M4
SYMATTR Value Si4850EY
SYMBOL cap -336 32 R0
SYMATTR InstName C1
SYMATTR Value 10p
SYMBOL cap -208 304 R180
WINDOW 0 24 64 Left 0
WINDOW 3 24 8 Left 0
SYMATTR InstName C2
SYMATTR Value 5p
SYMBOL diode 336 32 R0
WINDOW 0 -33 98 Left 0
WINDOW 3 37 33 Left 0
SYMATTR InstName D3
SYMBOL diode 336 160 R0
WINDOW 0 -33 34 Left 0
WINDOW 3 40 94 Left 0
SYMATTR InstName D4
SYMBOL cap 240 128 R0
SYMATTR InstName C5
SYMATTR Value 5n
TEXT -176 688 Left 0 !.tran .5
TEXT 40 696 Left 0 !;ac oct 5 20 20000
