have a few question for those in the know.
I have been using swordfish basic compiler for a long time now and I am very happy with it, but I have a need for using faster processors and for hobby's smaller ones than the 18 series pics.
1. Is the syntax the same across all three compilers, I've had a quick look at the 18 series to compare to swordfish.
if so
Do they support overloaded subs and compound subs? it didn't seem obvious to me.
Compound subs are so useful particularly with comms.
eg
do they support bit, byte and sub/function aliasing
so can you do things like the following
Finally can I use the 8 bit compiler indefinitely with the 2k limit? as a hobbyist
Richard
if so
eg
Code:
// overloaded sub to output a string...
sub WriteItem(pValue as string)
something here to write a string
end sub
// overloaded sub to output a byte...
sub WriteItem(pValue as byte)
something here to write a byte
end sub
// create compound subroutine...
compound sub Write(WriteItem)
// make the call...
Write(10,"Hello World", 13, 10)
Code:
dim Value as word
Value.Byte1 = $FF
dim Array(10) as word // a word array
dim ElementAlias as Array(3) // alias to element 4
dim ByteAlias as ElementAlias.Byte1 // element 4, high byte
dim BitAlias as ByteAlias.7 // element 4, high byte, bit 7
Richard
