Microwave oven temperature probe port grounding
Tom Del Rosso
Just wondering what would happen if a metal container was used in a
microwave, but grounded to the phono jack for the temperature probe.
Assuming the connection was good, of course.
bz
The 'grounding' would not help.
A 'good ground' at microwave frequencies would be much less than 1/4 wave.
The wavelength is about 3 cm.
A good ground would thus need to be much less than 1/2 cm.
A metal container is probably going to arc to the inside of the oven in
several places.
It may detune the cavity badly enough to present a high SWR to the magnetron
and damage or destroy the magnetron.
bz
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
Michael A. Terrell
The wavelength is too short for any effective grounding, and that is
a 1/4" Phone jack, not a phono jack.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Tom Del Rosso
wave. The wavelength is about 3 cm.
in several places.
magnetron and damage or destroy the magnetron.
Very interesting. I thought the wavelength was a few inches.
So how does the probe get away with it?
Sam Goldwasser
He meant to say 1/4 wavelength is around 3 cm. :) The wavelength is
a few inches, like around 5 inches.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
bz
Actually, I was thinking x-band radar was very close to the microwave oven
frequency. I was wrong.
The X band ranges from 7 to 12.5 GHz.
The microwave ovens actually operate in the S band, the 10 cm radar band. The
S band covers from 2 to 4 GHz.
According to http://hypertextbook.com/facts/1998/HowardCheung.shtml
most microwave ovens operate on 2.45 GHz which gives 11.8 cm wavelength, 4.6
inches, for a quarter wave of a little over one inch or 2.95 cm
In any case, it is still a bad idea to put any metal bowls into your
microwave over, unless the metal object has been designed for use in a
microwave oven.
bz 73 de N5BZ k
I fixed radars for a living in the mid 70's. I had a 1st class radiotelephone
license, second class radio telegraph license with ship radar endorsements.
infinite set.
Tom Del Rosso
Ok, but the probe is over 6 inches long without the plug, so why doesn't it
collect a charge? I always assumed it was because of the grounded plug.
