Terry said:
I've set -40 and -52 on fire (well the coatings and wire insulation), as
well as -26. -2 is harder to do that to, as its mostly not there. I've
smoked up some metglass too.
koolmu is pretty good, and MPP is better, as JL said. I like ferrites,
but the peak flux is lousy.
Cheers
Terry
There is nothing wrong with iron powder cores from Micrometals or TSC-
Pyroferric provided you get the right balance between core losses and
winding losses in your design.
I've been a choke/inductor designer for winding companies for over 25
years, and have many thousands of my designs of iron powder cored EMI
filtering and storage chokes in use around the World.
The lower loss powder cores (MPP & Sendust/Kool-Mu) are OK for small
chokes, where labour costs are higher than material costs, but try
using cores of 3.06" diameter and upwards and see just what cost
penalty you pay.
Fortunately you would normally be into high power / low frequency
(c20kHz) switching here, so it's possible to succesfully use
Micrometals -34 grade for chokes like 6kW pfc chokes for applications
like film lighting ballasts, for instance.
Cheers
Paul Brown
