Hey all hoping for some help on a repair for this one, Its been some time since i worked in electronics (12 years) and id appreciate some advice.
The unit is basically a thermostat for switching reptile heating, it uses a lm393 voltage comparitor and switches the output via a 24vdc relay.
The issue is that sometimes the relay will switch on for around 5 seconds and then softly switch off (led on light in the relay trigger circuit remains on). This fault seems to be temporary as sometimes the unit will run for days without fault, othertimes the fault is persistant and just seems to clear after been unplugged a while. Iv metered the drive to the relay coil and it would seem im only getting 6.5V there when working and when the fault is apparant the voltage seems to drop to around 6v, obviously something amiss for a 24v relay.
Already swapped the relay out for one with same specs as initially i believed this to be the problem.
Noticed some browning to the 470 ohm resistor (top of board) metered it out correct but not while live.
Hope someone can give me some advice on this one.
Cheers Brett
Cheers Brett
